BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: clutch problems NEW TOPIC NEW POLL POST REPLY
draggsxr1000
posted October 01, 2004 06:12 PM
clutch problems
I recenty had a clutch failure. Clutches started slipping. So i removed them and found one bad fiber. Looked like the outer edge of the pad was gone. IT wore threw the pad into the metal. BUt just in a two to three mm wide strip all the way around. No other fibers where worn like this. SO i replaced this one and clutch seems ok but i have a lot of free travel. any ideas i just had put in a clutch cushion. 01 gsxr 1000 prob about 40 passes on this clutch
kzz1
"Show me whatcha workin with"
posted October 01, 2004 06:22 PM
Better drop the oil pan and check the oil pump screen to make sure the fibers are not clogging the screen. Might want to also check your steels if they are warped and measure your fibers to whatever the factory specs them at.
draggsxr1000
posted October 02, 2004 12:15 PM
how do u go about checking your steels i laid them flat on a table. The looked straight. As far as the oil goes im changing it right now but there dont seem to be any metal in it. I have check it real well i think it just barely scraped the fiber just enough to change the color. Its only one thousandth of an inch below the rest .
BA
posted October 02, 2004 08:13 PM
Two ways to check the steels.
Use a sizeable piece of glass as it will be perfectly flat,.....or,....I put all my steels next to each other and hold them in my hand while looking for gaps.
I then move a steel to see if the 'gap' moves with it or stays put because it was the adjacent steel plate.
draggsxr1000
posted October 02, 2004 08:30 PM
Got ya. But i did look at them and they didnt look bad to me at all. Here is the thing if this plate was warped the other fiber it hits against should have shown some abnormal wear. Or atleast i would think. If one side was hitting at the top wouldnt the other side be hitting at the bottom.
draggsxr1000
posted October 02, 2004 08:32 PM
I jsut had the clutch out of this thing less than a week ago. I personally think i might have got some type of grit in this thing something very light that would really affect steel. Plus i didnt have any problems till i put in this kit. All of a sudden im having to adjust clutch a lot. LIke every three passes. I havent adjusted the other one a single time. More than 60 passes on it. Who knows but i got me a new clutch anyways.
draggsxr1000
posted October 03, 2004 06:35 PM
Well i stand corrected. I Found several bent steels one being real bad where the last clutch fiber was worn out an another on the way. Will these bent steels cause the clutch to slip.
ninja12
posted October 03, 2004 06:53 PM
YES! and wear out the rest of the pack too.
kzz1
posted October 03, 2004 07:02 PM
Are you using o.e.m. steels and fibers? O.E.M. are far better than any aftermarket fibers or steels. Aftermarket are good for street riding but not at the dragstrip. Trust me I know
BA
posted October 04, 2004 07:15 PM
Do you think you're slipping the clutch out longer, or launching at a higher RPM than on the previous clutch pack? If so, that might explain why you are adjusting more now.
When we start out and are timid or learning the bike, I think we're all not as aggressive as we become a month or three later.
draggsxr1000
posted October 05, 2004 05:57 PM
damn right ba The aggressive this so right. But i had four bent steels plus after a few cal. my clutch had over 100 passes. So i think i got the good out of it for sure.
BA
posted October 06, 2004 01:27 PM
based upon that answer, I don't think you've got anything "wrong" or "bad" there,.....just the symptom of excessive heat build-up which warps the steel plates, caused by high rpm and slipping the clutch out.
Correct me if that's wrong.
When you read about many of us 12R guys making "oiling" mods or waiting 15-30 between some runs, it's to prevent that warping.
Ditto the move to the "muzzy clutch kit"....it uses all 2.0mm steels instead of the thinner ones, thus they dont' warp quite as easily.
when you take your clutch plates out, are they dry-ish or are they slightly wet with oil film?
draggsxr1000
posted October 06, 2004 04:22 PM
dry
draggsxr1000
posted October 06, 2004 04:23 PM
but i did buy a salvaged motor that had sat for a while so who knows
BA
posted October 06, 2004 06:33 PM
dry
Not surprised!!
same symptoms as the 00 and 01 12R's early on......
salsa1
posted October 07, 2004 05:12 AM        Edited By: salsa1 on 7 Oct 2004 12:20
POSTED ELSEWARE.
Salsa1
BA
posted October 07, 2004 06:25 PM        Edited By: BA on 7 Oct 2004 19:27
0.27191495895386 seconds processing time
