BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Air shifter mountig? ZRXrs NEW TOPIC NEW POLL POST REPLY
YTRAP
posted January 27, 2002 05:40 PM
OK I got where do I put it? and Should I mount it so its at the end of its throw when the shift is complete?
ZRXDean
posted January 27, 2002 09:15 PM
There's certainly more than one way to mount it, but here's how I did it. Sorry about the crap pics, but you get the idea. The shift cylinder needs to be 3" off center, and should have 1/16-1/8" of travel remaining at max extension. Also be sure to mount it as close to plane with the shift lever as possible, and leave it a little play to rotate and twist. I run nitrous (easy to get) with a 140psi regulator. Better than filling up after every run. I also run an MPS adjustable kill box, at about 75ms, shifting at 10250. I spent about 3 hours just putting the hole in the tailsection to mount the bottle, and maybe 8 hours on the rest of it, but I take my time.
Dean
ytrap
posted January 27, 2002 11:20 PM
Thanks Dean, I was planning on using CO2 for the sam reason. I'll put up some pics when I get it all set up
Of course its stock.
YTRAP
posted January 29, 2002 03:29 PM
Ya know Dean I had myself talked out of nitrous till now. UH OH :o
hondo
posted February 19, 2002 09:29 PM
Hey ZRXDean! Is the rear axle for the ZRX the same diameter as the 12's rear axle?
ZRXDean
posted February 19, 2002 09:37 PM
Not sure. I'll let you know what the ZRX uses though.
Por que?
0.41228890419006 seconds processing time
