posted August 27, 2004 03:44 PM
LM-1 AF/data logger - part deux
woo-hoo!!!
My TPS signal was "buzzy", so i went looking for a better ground (like the manual says to do: RTFM, one more time)
I ditched my frame ground, and took the br/bk (#60)ground from the ECU and now the TPS & RPM signals look fukken perfect.
man this thing is COOL!
Now I know that it takes .21sec to rev from 4050rpm to 11,400rpm when you twist fast from 4.5% to 98.3% throttle position.
Now, THAT'S some useful data, eh???
Best toy in my garage
Also, looking at the Kwak schematic, it seems all the temp & pressure sensors use the same ground, so I imagine hooking up some more stuff should be as easy as pie.
spencercyclecom
posted August 27, 2004 10:33 PM
Thanks carl for the very good feedback and thans goes out to all the guys that are buying these....you guys are "in th eknow" and now you are going to look back and wonder how the HELL did you do with out this.
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
spencercyclecom
posted August 27, 2004 10:35 PM
Carl....
did me describing to you how to cusotm enter the values (0-5v) help?
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
posted August 27, 2004 10:58 PM
yep; thx for being so patient with my questions. You pointed me in the right direction.
I didn't need to screw with the table, but the soln was as easy as RTFM.
When setting up the rpm module, let the software set the rpm table by holding the rpm steady at 4000 rpm rather than 2000 (using the set up SW); then when recording/playing back the data, simply check the box on the rpm option which doubles the rpm range.
bottom line is i have rpm which reads correctly, e.g 8000rpm reads as 8000 rpm and the range is 0 to 20,460, so no clipping at 10,230.
Man o' man this thing is SOOOOOOOOO EASY, once you get just a bit familiar with it. very simple to use.
johnnycheese
posted August 28, 2004 04:24 AM
so far I think it is kick ass
10rmotor
posted September 04, 2004 01:42 PM
leaded race gas compatibility
How does leaded race gas affect the O2 sensor, or wideband sensor?
spencercyclecom
posted September 04, 2004 01:49 PM
it will cut the lifespan down a bit......but this is the same with ANY o2 sensor. Good news if the sensor goes bad...they are only $59.00 and available from an autoparts store.
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
posted September 04, 2004 01:50 PM
i'm using gas w/7gm/gal lead and the manual says i will shorten the life of the sensor to 50?? hrs.
bahahahahahaha... LOL
in 50 hrs of run time i 'll go thru so many motors, the least of my worries are wideband sensors.
Even for folks who wanna use this on the street; how much leaded gas are you gonna put thru it???
10rmotor
posted September 04, 2004 03:37 PM
I'm thinking of using the O2 sensor on a 10R in a road race car, and so with two hours average track time, it will last more than two years. 50 hours is no problem.
posted September 05, 2004 02:11 AM
10rmotor,
i just checked the manual and it said lead will damage the O2 sensor after somewhere between 50 and 500 hrs of operation so i guess we are both covered.
10rmotor
posted September 05, 2004 08:45 AM
Right on, thanks. Now just gotta get this thing running.
NINJA12
posted September 07, 2004 01:10 PM
Carl,
keep all your notes, i just ordered mine and i'm gonna need LOTS of help.
LOL.
Thanks to you and JC, for all the testing .
posted September 08, 2004 01:08 AM
Ninja12,
ALL RIGHT! You'll have it up and recording toot sweet!
NINJA12
posted September 10, 2004 08:39 AM
Edited By: NINJA12 on 10 Sep 2004 09:40
Doug you are the man! I got it already.
I ordered it 9/7 and it's on my door 9/9.
GREAT SERVICE, THANKS !
Carl, do you have any pictures of the install?
posted September 10, 2004 11:11 AM
ninja12, no pix; my kids keep gleeping my digital cameras.
The bax fit very well on the ram air cover, AND you can easily get at the on-off switch and record button.
If I run into someone at the track tonight w/a digicam, i'll see if i can get some pix.
Good luck on the install, VERY easy.
ninja12
posted September 20, 2004 04:51 PM
Done Deal,
VERY EASY TO INSTALL.
1. get bung installed in pipe (that's the hard part)
2. cut power cord connect red wire to pos, black to neg at the battery.
3. power on lm-1 and hit calibrate button.
4. install o2 sensor in pipe.
DONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
TPS/RPM option
1. ground................... brown/black wire @ cpu
2. RPM ......................black/orange wire @ cpu
3. TPS..........................center wire of TPS @ TPS
(anyone know which wire is tps @ cpu)
Follow instruction in software to setup rpm module.
spencercyclecom
posted September 20, 2004 07:50 PM
will post in the morning which it is.....
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
posted September 20, 2004 09:57 PM
ninja12,
COOL!!! You are making progress!
TPS output voltage is ECU pin #42, yellow/white; standing behind the bike looking down at the ECU its the left ecu plug; lowest row of wires, 2nd one in from the left.
NINJA12
posted September 21, 2004 06:53 AM
Edited By: NINJA12 on 21 Sep 2004 07:54
All this information with just 5 wires, 2 to the battery and 3 to the ECU.
Hint ...you CAN'T use the tach signal for RPM,
and you can't run the setup and monitor program at the same time.
Thanks again Karl,
Like kevin cadby said you'll be suprise at how much time you spend at
5% throttle or less!
