BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Shock Info NEW TOPIC NEW POLL POST REPLY
01zx12r
posted July 13, 2004 06:03 PM
Shock Info
How many people are running an aftermarket shock or re-valved shock? I had a re-valved shock and am now shopping for another option. 2001 zx12 66 1/2" wheelbase and 300+ hp.
Lovett Racing/Pedigo Performance
8.40 @170
bossman12r
posted July 14, 2004 04:44 AM
I had NLR revalve my shock, it is alot more adjustable than before.
gen 4 zx10 is fast
posted July 14, 2004 05:39 AM
So far, the best shock out there is also the best for the 12. Ohlins makes a shock perfect for the 12. You can adjust the spring tension while sitting at a traffic light.
your car is slow
Fuck Nitrous...Got Boost?
posted July 14, 2004 06:02 AM
Going to try a Fox shock that steve is loaning me for the new project...supposed to be shorter than the stocker and allows for more adjustment.
Do not taunt happy fun ball!
posted July 14, 2004 07:43 AM
The Ohlins has about 2 inches of ride height adjustment also.
01zx12r
posted July 14, 2004 03:37 PM
The shock that failed was a stock revalved NLR unit, I wont go that route again. Trust me when a shock fails on a run and you loose all the compression dampning, you shoot for the sky almost faster than you can think. Cracked an oil pan and scratched up the tail section. I guess I will check some options before I order something soon.
8.40 @170
posted July 14, 2004 05:51 PM
O1... do you have a cut oil pan? Do you run a sidewinder? Turbo?
If you notice, the oil drain plug is the lowest. Once you address this, then the headers are the lowest point. If you go to a sidewinder, then the shock clevis is the lowest point.
01zx12r
posted July 15, 2004 01:33 AM
Oil pan is cut, No sidewinder and really dont want one LoL
I plan on making some mods to the pan to elminate future mishaps.
8.40 @170
posted July 15, 2004 05:56 AM        Edited By: CrotchRocket on 15 Jul 2004 07:03
Alot of guys are using the Penske 3 way shock for $ 1000.00...I heard that the Fox shock leaks and needs revalving sooner than Ohlins and Penske...
Penske is made in the USA and is easier to get parts and revalving than the Ohlins!!!
The Orient Express team uses Penske!!!
Rickey Gadson uses the Fox shock!!!
check out https://secure.traction.com/products.shock.shtml
0.2106659412384 seconds processing time
