BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: gsxr 1000 NEW TOPIC NEW POLL POST REPLY
draggsxr750
posted May 22, 2004 05:56 PM
gsxr 1000
thanks for all your help with my 750 but by request due to my weight i have since dropped tha lil motor out and added a 01 gsxr 1000 bike dyno at 155.3 is this good or even comp any ideas what this thing should run in 8th mile thanks guys and gals
krexken
posted May 22, 2004 06:46 PM
I think stone stock 01 made around 143 so it sounds like yours runs quite well. 6.50s? around 112-115? Aw heck, just go run it and be done with it!
posted May 22, 2004 07:07 PM
It all depends on whos riding and their skill level...maybe 117 in the 8th on a 60" with weight on the front...
draggsxr750
posted May 22, 2004 08:35 PM
i run my 750 several times still getting used to tha power difference so thanks guys
BA
posted May 23, 2004 07:10 AM
heheh, you'll have to make a new Board Name!
good luck with the 1K.
draggsxr750
posted May 23, 2004 05:55 PM
hell yea good idea
prob not use this on everything lol thanks for ya luck
draggsxr750
posted May 23, 2004 05:56 PM
any ideas on how to launch this beast and tire selection
BA
posted May 23, 2004 07:23 PM
a friend of mine gets his best results, on a stock arm, by doing the very high rpm launch. ie. same as my best results on the 12R. 5000-6000 is a starting point.
I'm not sure if that's the best idea with your setup........I can tell ya that a good reference point is in your torque curve. If you get the clutch all the way out too far below the curve, it'll hurt the ET.
draggsxr750
posted May 24, 2004 06:12 PM
ba is he slippin the clutch or not and also what gears are he using
BA
posted May 24, 2004 07:08 PM
he is definitely slipping the clutch out. (for the first 2 years)
his gearing was -1T/-1T (not much change from stock actually)
He would normally run in the 9.5 range, but I've seen a few 9.4's and one great 9.39 run.
he only weighs about 155. being heavier, you're going to want more gear.
0.2647500038147 seconds processing time
