BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: ping swft NEW TOPIC NEW POLL POST REPLY
kllrvet
posted April 28, 2004 06:03 AM        Edited By: kllrvet on 28 Apr 2004 11:55
Ping swft
A month or so ago, you replied to a post regarding a manual fan switch. You mentioned using the emergency flasher switch. I tried doing this, but must have misunderstood. I carefully removed the orange and grey pins from the plug. I then made connectors to wire everything up, very neat clean, and easily removable. It worked great, press the flasher button, and the fan came on. Later on, I had to replace the flasher relay (I have LED rears). When I activated the right turn signal, the fan came on!
Any ideas as to what I did wrong?
Thanks,
Tony
ZX14 cam chain tensioner making noise? I have the set it and forget it fix. PM me if I can help.
posted April 30, 2004 05:51 AM
Hey Tony,
You can't have the switch still in the blinker circuit
kllrvet
posted April 30, 2004 05:56 AM
I didn't think it was still in the blinker cicuit. I removed the orange, grey, and green wires from the connector by the head.
Tony
kllrvet
posted May 02, 2004 02:04 PM
Got it
I got the switch working. I took the left pod apart and got into the wiring from there. Works great.
Tony
0.24650001525879 seconds processing time
