BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: muzzy nitrous upgrade NEW TOPIC NEW POLL POST REPLY
ninja12
posted April 20, 2004 06:55 AM        Edited By: ninja12 on 20 Apr 2004 21:45
Muzzy Nitrous upgrade
I really like the way muzzy eliminated the fuel pump in
their wet nitrous kit. No pump to turn on or burn up is impressive.
I wondering if i could upgrade my NOS kit with
the muzzy high volume fuel pump and regulator.
your car is slow
Fuck Nitrous...Got Boost?
posted April 20, 2004 09:22 PM
id be interested in an AFPR separatly as well.
Do not taunt happy fun ball!
ninja12
posted April 21, 2004 10:47 AM
ok, let me ask this another way.
If you have nitrous experience, speak up!
Is there any reason why i could not tap into
the stock fuel line and put a regulator on it
to feed my nitrous?
I am aware of the short coming of the 2000 pump.
your car is slow
posted April 21, 2004 01:44 PM
no..i dont see a reason why a fuel pressure regulator couldnt be fitted to a stock fuel system.
ninja12
posted April 21, 2004 01:49 PM
That's what i thought, but i hate it when i do something
and everybody but me knew it wouldn't work.
Lorcan
posted April 22, 2004 12:09 PM
That's the way EFI nitrous kits have been for years. Pump for carbs, red regulator for EFI.
  Ignore this member    Click here to visit Lorcan's homepage.
ninja12
posted April 23, 2004 08:27 AM
red regulator, huh.
that's what i really needed to know.
can you recommend a brand or model.
THANKS!!!!
Lorcan
posted April 23, 2004 10:16 AM
The red regulator is an NOS part. Schnitz should have them in stock.
810cc - 211mph: www.750turbo.com
wezze93
posted April 25, 2004 06:40 PM
i have 1290 je piston in it an will the stock fuel pump on a 2000 be enough for the nos
  Ignore this member    Click here to send wezze93 an AIM message.
posted April 25, 2004 07:50 PM
Pretty close...Muzzy says the stock pump gives up around 200 hp, which you should be knocking on right now NA. Add in NOS, you might not be able to maintain sufficient flow and go bad lean...
your car is slow
posted April 25, 2004 08:52 PM
stock pump is good to alot more than 200hp
wezze93
posted April 25, 2004 10:40 PM
thanks i will dyno it an see how it do
0.23031187057495 seconds processing time
