BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Degree cams in bike? NEW TOPIC NEW POLL POST REPLY
01zx12r
posted April 13, 2004 09:13 PM
Is it possible or is it harder than just pulling the engine. Mike....will your kit make it easier? We have set the cams on the bench but now have to try to set them in the bike. Any help would be appreciated. Thanks....Chris
Lovett Racing/Pedigo Performance
8.40 @170
catman12
posted April 14, 2004 03:08 AM
I degreed my cams in bike this weekend. It coulld be made.
// Mikael
6.23@126.7mph 1/8mi , 9.44@150.99mph 1/4mi 60" Arm, 1361cc, manual shifting.
http://www.kiruna.se/~mgrape
  Ignore this member    Click here to visit catman12's homepage.
posted April 14, 2004 09:09 AM
what I would suggest is leaning the engine forward (take out the top motor mount bolt. and that gives you more room. couple of options. you can take the rubber boot off of the intake and put a flat piece of steel there and bolt it on (this is what I do). or you could take a flat steel plate and bend it 90deg. and then bolt it on to the side where the radiator overflow goes. (this is what I am going to do with my next set up). Setup is really the hardest part of this ordeal! but once you find the perfect set up then it is all down hill from there.
give me a shout if I can help out!
515-491-1820.
after 5 central is the best.
oh on the kit it just has everything in it! and makes it easier to find TDC. and makes it perfect. you use TDC for alot of things in this bike.
0.20671200752258 seconds processing time
