BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: auto shift NEW TOPIC NEW POLL POST REPLY
lonniemac
posted April 02, 2004 05:34 AM
auto shift
is anyone using a dana shiftlite to autoshift on the electric over air setup. if so which wire is pos and which wire is neg. thanks guys.
DR JOE
posted April 05, 2004 10:05 AM
Are you using all Dyna stuff?? If not, it will not work...
Been there done that..
You will need to call MPS and get one of there Auto shift units. It will work with just about anything out there using a ground as the shift.
http://www.mpsracing.com/products/MPS/au01b.asp
You will need the 1-0010 unit to work with your shifter..
If you need anything else let me know.
DR JOE
0.20933389663696 seconds processing time
