BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 24V starter diagram NEW TOPIC NEW POLL POST REPLY
ra12r
posted March 20, 2004 12:25 PM
24V starter diagram
I need to the wiring instruction to make the starter run off of 24volts.
moonzx12
posted March 20, 2004 06:21 PM
no diagram but here we go:
from the starter solenoid to the secound bat. negative(-)
from the positive(+) of the secound battery to the starter.
now you have a 24v starting system
ra12r
posted March 21, 2004 06:42 AM
So, let me repeat this to make sure i am visualizing corectly.....
leave the first battery connected "AS IS"?? Then add the Neg(-) of the 2nd batt to the side of the relay that the Pos(+) of the OEM batt connects and then add the Pos(+) of the 2nd batt to the other side of the relay that goes to the starter.
If I am correct, will this create a circuit loop putting 24V in the whole system when you hit the starter?
posted March 22, 2004 12:24 PM
nope,
just "break" the circuit that goes from the relay to the starter, put the 2nd battery in series with that circuit. the - side of the 2nd battery should be attached towards the relay, the + side towards the starter.
That way the 2nd battery only is used when you hit the starter button. BUT, it is not charged, so you prolly want to put a pig-tail on the second battery so you can easily charge it.
Ra12r
posted March 22, 2004 05:24 PM
If I do it that way, will it try and engage the starter when I try to charge the second battery?
posted March 23, 2004 12:58 PM
nope, (at least i dont think so)...
moonzx12
posted March 23, 2004 06:23 PM
nope connect your battery tender or charger of sort and just plug in when needed
0.28710293769836 seconds processing time
