BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: WET KIT FOLLOW UP ZRX DEAN NEW TOPIC NEW POLL POST REPLY
DIGGSMS
posted March 16, 2004 09:33 AM
ZRXDEAN DO YOU HAVE ANY PICS OF YOUR INSTALL? ARE YOU RUNNING A PROGRESSIVE CONTROLLER? ARE YOU GOING TO ATALNTA TO THE PROSTAR RACE IF SO I WOULD LIKE TO SEE YOUR SET UP AND PICK YOUR BRAIN.
THANKS GREG
zrxdean
posted March 16, 2004 11:21 AM
Here' some pics and info from the original install Greg, but I'm running a Zukinut controller now. I should be at the Atlanta race though.
http://plaza.ufl.edu/sabat/NX.html
DIGGSMS
posted March 17, 2004 12:31 PM
YOU ARE THE MAN DEAN
COOL PICS THAT HELPS. I was debating about the fuel valve.
i guess i need to get the pingel. i am going to use the nos pump and the schnitz 2 dial progressive controller. the other ones seem to have too many features. do you use a button or do just use the wot switch and does the controller reset if you lift or let off the button?
thanks again
greg
i am definately coming to atlanta to see your setup first hand.
hey Dan i am getting closer, i can almost smell 200 can you?
DIGGSMS
posted March 17, 2004 12:52 PM
pingel
what is the part # for the fuel valve you have
zrxdean
posted March 17, 2004 02:02 PM
I just use the WOT switch, and both the NOS 5-dial and Zukinut will pause and resume if I lift, up to 20 sec I think.
The valve is a Pingel Guzzler GV111G, with 2 outlets, 5/16 diam, and needs a A1602 adapter plate for the ZRX tank. I think about $100.
Good luck, and see you (& Dan) Atlanta.
oldkawboy
posted March 18, 2004 04:46 AM
Wood,
No doubt in my feeble mind about the 200, may have to put the shrimp on it (as Guthtrie would say).
Dean....Missed you in G'ville. Looking forward to meeting up again in Hotlanta. Good luck.
Dan
DIGGSMS
posted March 18, 2004 10:39 AM
THANKS
THANKS DEAN
GREG
0.20780396461487 seconds processing time
