BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 1361 crank - should I question the quality? NEW TOPIC NEW POLL POST REPLY
RAC4IT
Bergie
posted December 27, 2001 08:48 AM
I'm not real happy with the physical appearance of the crank. It would appear that they took a lot of material out for balancing (which I know is normal) but specifically on one counterweight the drilling was off center somewhat. Should I assume it is fine? The Lunati stroker in my Z28 didn't look like this; it has precisely drilled holes.
This is what I am talking about:
Looks somewhat sloppy but as long as it's balanced I assume it's fine. Anyone else's look like this?
anesthesiac12
posted December 27, 2001 09:26 AM
I looks awfully sloppy. Mine wasn't like that at all. Did you get the kit from muzzys? And did they have the crank done by falicon or one of there other guys. They were getting a little backed up with orders for the cranks anf Falicon wasn't turning them around tp fast. Maybe its a lemon. Before you put it in id have it checked....
anesthesiac12
posted December 27, 2001 09:33 AM
I just looked at your aditional photos and it doesnt look like a falicon crank. Ive had a few cranks done by them and they all shared the same characteristics which yours doesnt apear to have
Its a good kit though, i put mine in in may and have had good luck with it. I just tore it down to change the rods and do some head work. Its all back together now.
krexken
posted December 27, 2001 03:08 PM
Mine looks nothing like that. I had a hard time telling that it was rebalanced at all. I think they just drilled the existing holes deeper on mine. I'm not too sure I'd accept it.
RAC4IT
Bergie
posted December 27, 2001 06:21 PM
Muzzys
I sent Doug an email and currently awaiting his response. Hopefully they will be able to tell from the photos what my concerns are. I've pasted some higher resolution pics here:
http://berg.fbody.com/rac4it/parts/DSC02276.JPG
The others ones are # 74, #75 and # 68 (just change the last two digits in the link) for the high res snaps.
toprat
posted December 27, 2001 09:27 PM
IMHO....The crank doesnt look very good. With the way the balancing holes are drilled it is sure to cause stress risers. Ive never had any bike cranks balanced but none of my car cranks looked like this. Even if Muzzys says it ok, I would ask for another one just to be safe since there are no warranties on race parts. If that thing goes your gonna tear up a whole lot more than just the crank. And for the price of that kit it should be gold plated anyway.
1991 ZX-11 Turbo
Too much is never Enough
YTRAP
posted December 28, 2001 09:04 PM
What a waste of a crank. Could've done better on my drill press in the garage. Send it back!!
Of course its stock.
ZX12Girl
Adrenaline Junkie
posted December 28, 2001 09:24 PM        Edited By: ZX12Girl on 28 Dec 2001 21:26
I am not an expert at this!!!
But that would not go back on my Bike!!!! Send it back!!
RAC4IT
Bergie
posted December 29, 2001 10:50 AM
update
Doug is at the NY show so I probably wont hear anything until the first week of January.
hondo
posted December 30, 2001 12:17 AM
I would like to see a larger picture like the first one you posted. I see a bigger problem than the web drilling! On the side of the web there is an area that looks like weld void, the dark pits. Also on the rod journal there appears to be some void/discoloration where there should be a nice little radius at the cheek to journal junction after the machining/grinding/polishing operations. Anybody who builds their own engine, be sure you have a chamfer on the bearings. In other words the outside edge of the bearings needs a little chamfer to clear the radius at the journal to web junction.
RAC4IT
Bergie
posted January 02, 2002 11:25 AM
Muzzys Response is Quick
Got a message from Doug today- he said send it back and they will properly inspect it and talk to Falicon (the manufacturer). Thanks Muzzys!!! Good customer service!
hondo
posted January 08, 2002 09:18 AM
I looked at the pictures MM posted of his engine build-up and took a good look at the visible portions of the crankshaft. The factory balance holes are not centered either but are away from the web walls. It looks like when it was balanced after stroking they just enlarged the original holes, causing the break-out. I would like to see the counterweight trimmed to reduce weight.
0.24594497680664 seconds processing time
