BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Valve Cover Bolt Seals help! NEW TOPIC NEW POLL POST REPLY
dchowror
posted December 13, 2023 11:52 AM        Edited By: dchowror on 13 Dec 2023 19:53
Hey Gearheads, this might be a simple question and perhaps I should just go ahead and do it but first I'd prefer to hear your thoughts. The bolt seals on my valve cover are seepy and I want to change them whilst I am in that area changing plugs. If I change the seals one at a time and retorque each one as I go will there be a problem with the valve cover gasket seal breaking and leaking later. If so I will just leave them alone. It is likely that they are originals and never been changed which is why they are leaky now. I appreciate any feedback from anyone that has tried this.
Thanks for your help!!!
DC
tuusinii
posted December 25, 2023 06:49 AM
It should work. But of I understood that the bike was new for you? So checking valve clearance should be onnyour todo list. 've reused the seal many times but of it has been there a long it makes sense to replace it. Also remembrr to separately buy those seals for spark plug openings. They are where it mostly starts to leak first.
tuusinii
posted December 25, 2023 06:51 AM
And of you allready have a leak on that area I would look first the cam postition sensor on left front corner. I've had that leak on both my 12. I fixed it by.removing, cleaning and sealing with liquid rubber (Kawa/Yama bond). Never had a problem after that in 100k km...
Quick Reply:
0.29664206504822 seconds processing time
