racerx
posted December 23, 2003 06:47 AM
Edited By: racerx on 23 Dec 2003 06:48
blueing on headers??
how much blueing on an aftermarket akra header pipe is normal?is it a lean condition that causes this?
i know some discoloration is normal but #2 an #4 are dark blue from the bolt flange to where curve gets straight.
#1 and #3 are also blue but not as bad but still look way too discolored.
also it seems most of the blueing on all 4 pipes is only on the outsides of the pipe.
i have a pc111 with a custom map installed.
i even checked it against dynojets map(just to see if was mappped real bad someway),
but it was very close to the way they had theirs setup,
actually each column was very close to what fuel they had but just a little richer or leaner in the columns by single digits.
i know the operator of the map i had didnt copy dj's,i watched him do the work the whole time,they even had that link thing software by d.j another member discussed before.
bike was mapped to an 13.2-1 a/f ratio.
any ideas on the overblueing here?
i woulnt be so concerned but it is pretty unusually dark,
i have never seen a bike that dark before.maybe its the akra?i heard they need more gas thats why i had the map made.
posted December 23, 2003 07:20 AM
I would not worry about it, sounds pretty normal to me and if your AF is correct which it sounds like it is. you should be good. do you do alot of putting around or do you run it up alot? from what I have seen it is very Hard to map at Low RPM's.
Mad Mike
posted December 23, 2003 07:43 AM
Hmmm stainless steel.. ..........turning different colors??? You dont say!!!...
Other than the A/F being abit higher than some like... you should be ok. You cant really map an Akra pipe well on a dyno. At WOT they love you to pour more and more gas to it. I would have never believed it either if I hadnt done back to back to back runs while experimenting with the fuel settings on a PC3r. Adding roughly 30% more fuel got me another 4mph in the 1/8th and another 6mph on top speed.
racerx
posted December 26, 2003 02:02 AM
sorry fella's i am new to this pipe,pc111,game.
appreciate the input.
i knew some bluing is ok but how much i didnt know.
believe me i know that mapping a akra is a bitch!
30% more fuel on the dyno!for real?...so:
usually in the 100% t.p setting(or w.o.t) on the maps regardless of which pipe you have i have seen on average -8,
to 12 being the highest number.
i have never seen anything in the 100% column with 20-30% fuel,
(custom map that is).
maybe i'll give it a try.
i can see why now some people rip that pc off with tha akra.
TURBO:what r.p.m did you start at in the 100% column adding that 30% fuel?
posted December 26, 2003 04:54 AM
racer, I have an Akra on my Blue ' 02 without a PC3r!!!...I had a PC3r on the Red ' 00 wich has a Muzzy pipe on it, the PC went bad and its never going back on again...
But if you intend on adding nitrous or piston kit then a PC3r is a must...
