BIKELAND > FORUMS > ZX12R ZONE.com > Thread: cable lubing thing: doesn't work worth a shit??? NEW TOPIC NEW POLL POST REPLY
posted December 19, 2003 04:12 AM
I got me one o' those cool looking lil cable lubing things that clamps on the cable, and you spray into a little hole, supposedly the oil is forced down the cable.
Didn't work worth a shit for me. Anyone have success?
slug
Out in search of my mind...
posted December 19, 2003 04:29 AM
yeh, maybe your cable is too small?
or there is a bad blockage.
i usually send a healthy dose of WD40 through first, thenuse the cable lube once it is all smooth and working
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
ScaredyCat
posted December 19, 2003 04:50 AM
Are the cables teflon lined? If so, you have to use special teflon lube or the insides of the cables can swell up and make the cables stick. I'm not sure if the cables are this type though.
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
posted December 19, 2003 05:11 AM
I just use the ol PB blaster and a rag. Works for me.
Dino
posted December 19, 2003 06:39 AM
I used one for years on the dirt bikes and it worked fine!
uh oh
claude
posted December 19, 2003 07:11 AM        Edited By: claude on 19 Dec 2003 07:12
On mine, the inner rubber part have different stepped diameters to accept differently sized cables. Be sure that you own cable is correctly inserted into the smallest diameter it will fit in before snuggly tightening the screw. If not, the lube will not find its way into the cable but, instead, will take the easiest path which will be all around the cable.
posted December 19, 2003 07:46 AM
Claude gave the best description yet! SInce you are possible the first person I have ever heard of having a problem, do not get insulted with the next few questions, but answer them.
#1, Are you trying to lube the clutch cable or the throttle or Idle up lever?
#2, Did you remove the cable drom the holder (Clutch lever, Throttle housing, etc)
#3, Did you slide the tool as far on the the cable housing as you could? (Large opening on the cable housing, small or no opening over the cable)
#4, Did you make sure the cable was in the middle before you tightened up the tool?
#5, Did you tighten up the tool as much as possible (By Hand)?
#6, did you insert the straw from the can of lube into the can and tool hole as far as possible?
If you did all of these things, and wrapped a few paper towels around the tool, you should have no problems.
You also did not saw "Exactly" what happened? No lube came out, it came out everywhere? What?
Ninjaman12R
as a Deal's Gap tour guide.
posted December 19, 2003 08:11 AM
Operator Error???
I've got one and it works great. You do have to have everything just right though, or you're just wasting lube.
posted December 19, 2003 10:08 AM
i becha i didn't take in account the stepped nature of the receiving end of the rubber thing. I'll try again this pm.
Thanks guys!
your car is slow
Fuck Nitrous...Got Boost?
posted December 19, 2003 10:41 AM
They actually make something to substitute sticking a plastic tube inside another plastic tube and pushing a button?
Damn :/
Do not taunt happy fun ball!
extremelean
posted December 19, 2003 04:04 PM
If its the little aluminum one....I've been using those things for years with maximum success.....I even wore one out last year that I have had for 16 years.
It should be no problem entropy....just re-asess the situation......you have to fit the luber onto the cable just right and fit the lube tube into the luber just right.
Did I say that...some of that didnt sound right....oh well....you get the idea!
LOL
Hells Dark Lord
living life, and loving it.
posted December 19, 2003 04:52 PM
any of you all use a graphite based lube called Dryslide? We use to use that on dirtbikes, cause it didnt atract dirt?
extremelean
posted December 19, 2003 09:58 PM
yes....dryslide is extremely good stuff
harryzx-12
posted December 19, 2003 10:50 PM
Mine works fine as it has for many years.I use molyd- disulfide lube same as dryslide i think.Sprays wet and then dries.It's used a lot on acft.
posted December 19, 2003 11:46 PM
EL,
....just re-asess the situation......you have to fit the luber onto the cable just right and fit the lube tube into the luber just right...
now i understand! yep works fine now!
slug
posted December 20, 2003 03:59 PM
sweet :-)
bagster
posted December 21, 2003 12:52 PM
There is usually a bit of spray lube coming out where the rubber can't seal against the braided cable perfectly.
I just wrap a rag around the whole thing before pressing the button on the spray can.
posted December 21, 2003 12:57 PM
bagster,
that's exactly my experience, now i found out about being careful on the stepped end.
posted December 22, 2003 05:22 AM
I have never used one? dont laugh to hard, I just buy a new cable. i may have to get a Lube thingy and try my hand at lubing........ LOL..
MM
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: cable lubing thing: doesn\'t work worth a shit??? NEW TOPIC NEW POLL POST REPLY
0.23696994781494 seconds processing time
