BIKELAND > FORUMS > ZX12R ZONE.com > Thread: From my daughter - you might have seen it before NEW TOPIC NEW POLL POST REPLY
redelk
Please... speak to the hand.
posted December 16, 2003 07:37 PM
Here's a list of tools and their typical usage. Anyone who has spent time working on cars will be able to relate to this.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing convertible tops or tonneau covers.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the Whitworth socket drawer (What wife would think to look in there?) because you can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell.
ZIPPO LIGHTER: See oxyacetelene torch.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for hiding six-month old Salems from the sort of person who would throw them away for no good reason.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against the Rolling Stones poster over the bench grinder.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Django Reinhardt".
HYDRAULIC FLOOR JACK: Used for lowering a Mustang to the ground after you have installed a set of Ford Motorsports lowered road springs, trapping the jack handle firmly under the front air dam.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor Chris to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and hydraulic clutch lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round-out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire, and rounds them off.
-Ernest Hemingway
posted December 16, 2003 08:16 PM
lmfao... dude those are so funny!
MM
posted December 16, 2003 09:22 PM
Yah, that's great!
Hells Dark Lord
living life, and loving it.
posted December 17, 2003 05:16 AM
dam sounds like my garage.....thats why I pay someone else to take care of my stuff....lol
necro
My Grandma Is A Virgin
posted December 17, 2003 10:31 AM
It's good that no one around here works for a tool company.
JoshDunn
posted December 20, 2003 04:55 PM
That is excellent!!!
0.22728586196899 seconds processing time
