BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Welding advice aluminum NEW TOPIC NEW POLL POST REPLY
zx12richard
The Green Monster..
posted December 05, 2003 10:19 PM
I want to put a NOS bottle in my swingarm in front of my rear wheel.... That way I have 2-2lb bottles on board....
But my question is...
Does the swingarm have to be removed to weld it??? Or undo battery or unplug ecu or any tips appreciated....
harryzx-12
posted December 06, 2003 04:40 AM
You shouldn't have to take it off as long as you can get the tig torch where you need it welded.Disconnect the battery for sure.I don't think it will harm your electronics. I have welded on acft in areas close to millions of dollars worh of sensitive electronics and it didn't harm any of them.
zx12richard
The Green Monster..
posted December 06, 2003 08:23 AM
Thanxxx Harry I have heard both ways..... I have a friend that welded on his 1000 GSXR on the subframe at least 5 times... Just wanted to make sure the 12 wasn't different...
zxlnt
posted December 06, 2003 02:36 PM
If you need a welder Richard let me. I have a friend here in Topeka who is a very very good aluminum welder...
harryzx-12
posted December 06, 2003 02:59 PM
Looks like zxlnt can hook you up richard. If your're worried about your computer unplug it before welding. I'd do it for you if You were closer.
your car is slow
Fuck Nitrous...Got Boost?
posted December 06, 2003 08:05 PM
If you have an EFIR box...dont weld without removing it!!
Do not taunt happy fun ball!
zx12richard
The Green Monster..
posted December 09, 2003 05:41 PM        Edited By: zx12richard on 9 Dec 2003 18:03
Thanxx Tony Topekas just a bit to far... I decieded to pull it.... And heres where I am so far...
Found a welder fella today... Gotta find a sandblasting fella tomorrow.... Already have a paint fella.... Was going to powder coat it but it was about 75 buck to replace the swingarm bearings..... So we will use a etching primer and paint.... Didn't do too bad of welds just some mild cleanup before paint..... Heres the idea.....
Still have this bad boy under my seat..
01zx12r
posted December 09, 2003 06:52 PM
Richard...Make sure you have about 3 inches between the valve and the undertail of the bike. I would rec. pulling the syphon tube from the bottle and mouting the bottle upside down in the swingarm.
Lovett Racing/Pedigo Performance
8.40 @170
ozzy
need guberment cheese
posted December 09, 2003 06:59 PM
Just a tip to remember about doing any type of electric arc welding, never let the ground path run through a bearing!
zx12richard
The Green Monster..
posted December 09, 2003 07:10 PM
Siphon tube has come of interest to me from another board.. Someone metioned turning it around..... Am I thinking right.... If bottle is right side up it draws off the bottom(flatside) of the bottle????? If bottle goes upside down remove it?????
wannabe
posted December 09, 2003 08:24 PM
I second this advice.
zxlnt
posted December 10, 2003 03:30 PM
Yeah if you turn the bottle upside down just take it out completely...
zx12richard
The Green Monster..
posted December 10, 2003 06:18 PM        Edited By: zx12richard on 10 Dec 2003 18:20
Well today was very productive....I went to find a sandblaster recommended by a friend... I got there he was riding his tractor pushing snow. I asked him about getting it sandblasted sometime. He said lets take it down to the shop (stopping what he was doing). When we got there I said whenever you get around to its fine.... To my surprise he started on it right then...Had to jumpstart his diesel air compresser and setup a table outside... Went outside and sandblasted it to bare aluminum for me for 20 bucks... I was very happy... Will go back there... So then I went to drop it off at my buddys to etch primer and paint and clearcoat it.... Got lucky... He was already spraying black paint today... Two jobs both black... SO needless to say I got it sandblasted,etch primered and paint and clearcoated all today... Great day... Now all I have to do is get the 2 needle bearings I ordered in and put it back together and order a NOS line..... Pics will follow but not tonight... So with the new welded bracket I have 70 bucks in a freshly painted arm.... 20 for weld,20 for sandblast and 30 for my buddy to etch prime,paint and clearcoat...
zx12richard
The Green Monster..
posted December 11, 2003 08:11 PM
Little dust on it in places but these are the finished pics..
0.22494411468506 seconds processing time
