BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Yellow box question NEW TOPIC NEW POLL POST REPLY
wannabe
posted November 10, 2003 05:22 PM
Yellow box question
OK folks, I was thinking about putting a yellow box on my bike to make sure that I don't hit the 186 mph limiter when I drop my gearing down for the dragstrip. Here's the deal. I checked the instructions on the yellow box site:
http://www.blackrobotics.com/index.htm
Unfortunately, it looks like the yellow box maxes out at a 28% correction. My math tells me that I need a 34.5% correction if I want to run a 16/55 gear ratio:
16/55 = 3.4375
18/46 = 2.55555555 (stock)
3.4375/2.5555555 = 1.3451 = 34.51% higher
Is there any way to bump the yellow box up to 34.51% correction or would I just have to live with a 6.51% error?
I know that it won't hit the limiter if I enter 28%. It's just that I'm figuring that if I'm going to pony up for a Yellow box, I want it to work 100%.
posted November 10, 2003 06:48 PM
I thought they made a high-ratio one as well...
wannabe
posted November 10, 2003 06:49 PM
Really? Anyone know where I can get info on that one?
posted November 12, 2003 05:49 PM
Just checked the web site, guess I was wrong. Course, you could always buy two and use them in series.
wannabe
posted November 12, 2003 05:54 PM
I just went ahead and bought the regular one. I can live with a 6% error. Heck, I'm living with a, 17% error right now since I'm not using a yellow box right now with the 16/48 gearing. Realistically, my goal is just to not bump the 186 mph limiter. This should take care of it.
lou_zx12r
One Day at a Time
posted November 13, 2003 09:53 AM
try the speeohealer.com i believe it corrects up to 60% and it is cheaper.
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
wannabe
posted November 13, 2003 10:04 AM
Doh!!!
wannabe
posted November 13, 2003 10:07 AM
Thanks, dude. You rock. Here's some info from the website:
Technical data
- Correction range: -69.9% to +99.9%
- Step/Resolution: 0.1%
- Accuracy on Speedometer: better than 0.05%
- Accuracy on Odometer: typically 0.5 meters (1.6 feet) regardless of the travel distance
- SmartTRIP frequency range: 0 Hz - 15 KHz
- Frequency range in correction mode: 5 Hz - 9.5 KHz
- Used mile/km conversion value: 1.609344
- Optimized, real time 32 bits floating point calculations
- Frequency-generator in Test-mode:
- Default frequency: 200 Hz
- Adjustable frequency range: 9.765625 Hz - 5.0 KHz
- Start-up time: 0.8 sec
posted November 13, 2003 08:12 PM
URL for it?
posted November 13, 2003 08:13 PM
Whooops, sorry, I should read better.
wannabe
posted November 13, 2003 08:49 PM
actually he put up a typo. Here's the real url:
http://www.speedohealer.com
0.40225696563721 seconds processing time
