BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Cyl head / Cylinder cut off? NEW TOPIC NEW POLL POST REPLY
catman12
posted December 19, 2001 07:54 AM
Someone know how much it is possible to cut off head or cylinder, with stock pistons and 93 octane?
Or is it perfect if I just remove the middle part of the
" 3 layer " head gasket? Is that enough, or to less to make difference?
/ Mikael from Sweden, Green 2001.
www.kiruna.se/~mgrape
mikael.grape@kiruna.se
6.23@126.7mph 1/8mi , 9.44@150.99mph 1/4mi 60" Arm, 1361cc, manual shifting.
http://www.kiruna.se/~mgrape
  Ignore this member    Click here to visit catman12's homepage.
Y2KZX12R
CompetitionCNC.com
posted December 19, 2001 09:02 AM
I wouldnt mess with the factory head gasket. Instead, remove the shim under the block. Its .010" thick and drops the block and head. The compression stock is 12.2 and removing the block shim will raise the compression to approx. 12.8 to 1
You can still run pump gas above 91 R+M/2
Y2KZX12R
CompetitionCNC.com
catman12
posted December 19, 2001 09:13 AM
Thanks Y2KZX12R!
Have you done it?
Will the cyl to block be leaking then?
Y2KZX12R
CompetitionCNC.com
posted December 19, 2001 09:39 AM        Edited By: Y2KZX12R on 19 Dec 2001 09:41
yea, I've been running my engine with the shim removed all year.
There is no coolant exposed to that shim.
Use an anerobic case sealer under the block.
You dont need to remove the pistons from the bores to clip and remove the shim. Just raise the block about an inch and clip one end of the shim and remove it.
But check your intake to piston valve clearance!!
You will need to buy cam gears to remove the shim under the block so you can set the valve timing.
Y2KZX12R
CompetitionCNC.com
catman12
posted December 19, 2001 09:46 AM
Thanks again Y2KZX12R!
Do you do some dragracing? I have done one and it will be
many more...
Here we have 1 ffet snow so the motorcycle is in the garage waiting!
This weekend it will be some snowmobile riding!
Arctic Cat ZRT 1107.
I Live 200 kilometers above the arctic circle in Sweden.
/ Mikael
Y2KZX12R
CompetitionCNC.com
posted December 19, 2001 10:19 AM
I havent had the zx12r to the track yet.
Wow you are WAY up there!!!!
I guess CT isnt so bad, we got 4" of snow so far.
My wife drove a C dragster for several years in the late 70's and eary 80's and even held a national record back then. There wasnt many females in racing at that time. You could count them on one hand.
The last drag car was a chevy barretta tube and glass car with a one piece nose and a Big Block Chevy 502/820 hp and was driven by my brother in law. My wife had lost interest by then.
Y2KZX12R
CompetitionCNC.com
0.23716497421265 seconds processing time
