BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Windows XP Question NEW TOPIC NEW POLL POST REPLY
necro
My Grandma Is A Virgin
posted October 29, 2003 06:55 AM
Windows XP Question
How do you prevent cettain programs from automatically loading in XP?
I know it's thr "run" command in the registery, but I don't know where to look.
your car is slow
Fuck Nitrous...Got Boost?
posted October 29, 2003 07:15 AM
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Do not taunt happy fun ball!
posted October 29, 2003 09:10 AM
More tech questions... make Brian earn his keep...lol
DaveInDaytona
posted October 29, 2003 11:02 AM
You can see the startup stuff without getting into the registry by running msconfig.
Start --> Run --> msconfig
Look under the startup tab.
DaytonaSportbikes Forum
Koz
posted October 29, 2003 11:11 AM        Edited By: Koz on 29 Oct 2003 11:54
Nero,
This looks/sounds worse then it is,
Click on start, programs, accessories, system tools, system information, in the next window on the menu bar, ckick on tools, system configuration utility, in the next window, click on the startup tab.
What you will see is a list of all the programs/etc. that are started on startup. You will notice that there is a check box next to each item. If you remove the check-mark from the box you will be able to SAFELY stop that item from starting the next time you reboot. If there is a problem after rebooting you put the check mark back and every is back to where it was.
DO NOT PLAY AROUND WITH ANYTHING ELSE IN THIS AREA, UNLESS YOU ARE FAMILIAR WITH IT!!!!!!!
Good Luck
Koz
necro
posted October 29, 2003 11:18 AM
Thanks your car is slow.
necro
posted October 29, 2003 11:19 AM
Thanks DaveInDaytona.
necro
posted October 29, 2003 11:20 AM
Thanks Koz.
necro
posted October 29, 2003 11:21 AM
Isn't it wonderful having all those resources available?
necro
This is it.
posted October 29, 2003 01:03 PM
Whore!
necro
posted October 29, 2003 01:39 PM
Yes..
0.22517204284668 seconds processing time
