BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 181x105 on the dyno NEW TOPIC NEW POLL POST REPLY
jimp
posted October 25, 2003 11:16 AM
181x105 on the dyno
Made 181 with a 105 pounds, the sad part is it's a 1287. Now maybe once I put a map in it the hp will go up, The bike is really rich, the ti pipe only has only blue back before the collector, time for a pc3R. Also noticed the sight glass just has a slight pocket of air at the top, too much oil.
Where's my 14 ???
posted October 25, 2003 12:36 PM
Hey Jimp with the bigger motor, do not skimp on the oil for sure!! or your bearings could be very sorry about that...
Mad Mike
zxlnt
posted October 25, 2003 02:34 PM
My 1270 made 181 and 101, but its a stingy ass dyno. Seeing as my bike made only 153 stock on same dyno. Your milage and dynos do vary. Dont sweat it.
posted October 25, 2003 04:17 PM
Yah, ride it!
Hells Dark Lord
living life, and loving it.
posted October 26, 2003 05:00 AM
my stock motored 12 made 154.3 hp, and I am not sure about the torque...the same motor after pipe PC, ignition advance, and K&N filters made 178.8 hp, and 97 ft lbs of torque on pump gas.....Kevin pulled 180.1 hp and 97 ft lbs of torque at his dyno in Jax on 114 gas......you guys are getting very good torque numbers Cant beat a good map to make everything work together.....
Ra12r
posted October 26, 2003 07:08 AM
Jimp, if you were basing your HP expectation on the HP post about 1270's here on this web sight, or Muzzy's then i truly understand your frustraton. But, you are right in the ballpark for accurate numbers for that particular piston kit. Remember you only added 90cc total. Also know this,,,,,,,,,,all these other guys here posting high 170's to 180's on stock motors would be destroyed by your bike at this point. So, enjoy your bike and don't believe the hype!
NOT TOO MUCH OIL!!!! Barely enough if you ask me.....look in your sight glass while running and it will be EMPTY,,,,,hmmmm
posted October 26, 2003 08:04 AM
Yep, there's a lot of that oil up in the head. But that's another thread!
k bryant
Sponsor
posted October 26, 2003 11:33 AM
Ra12r - there's no "hype" about getting those numbers with an internally stock engine. So if he's putting out those numbers, then he indeed would be within reach of those stock, finely tuned engines.
When he gets it dialed in with the pc3r, then he should be well ahead of any stocker and can take full advantage of the kit.
posted October 26, 2003 01:44 PM
Id like a shot at running it Jimp. I already know Id lay "Z's" fleet to waste...lol
ra12r
posted October 26, 2003 04:46 PM
OOOOOOO"K", that is my experience with my 1270....I made a grand total of 170hp with a pc3 using the y2k exhaust mod. But, I will say this,,,,none of those muzzy piped zx12's making over 170 could touch me.........smile
necro
My Grandma Is A Virgin
posted October 26, 2003 07:51 PM
Wow jimp that's 19005.
NORTY
posted December 01, 2003 06:52 PM
Wow,I thought the Muzzy kit was supposed to be good for 200hp?! 135Tq.
A NOD IS AS GOOD AS A WINK TO A BLIND HORSE
zxlnt
posted December 01, 2003 09:16 PM
Right.... Maybe a very very well tuned might make the 200 ponies but aint gonna make the 135 ftlb for torque...
posted December 02, 2003 12:05 AM
jimp,
i'm with ra12r; dyno-schmyno... (for comparison of different bikes on different dynos on different days)
get the pc3r mounted, tune on a dj250, and go to the track and kick ass. 1/4mi mph is the lie detector of hp measurement.
Hells Dark Lord
posted December 02, 2003 07:23 AM
remember fellas, racing is as much rider as it is bike...you may turn some serious numbers on the dyno, but if ya cant ride it, someone with a lesser bike is gonna dust ya....I got beat by my buddies RC51, twice in a row....not because he put more HP out, but because my dumbass redlighted twice, like I needed to get the jump on him....lol
But it is nice to have braggin rights though
psycho1122
posted December 02, 2003 08:00 AM
Over and over and over again I see the same results w/ dj250's. The Dyno has some limitations on determining what the correct A/f ratio needs to be !! Dyno Jet teaches new operators to "Tune" The bike to 13.2-13.4 a/f. That is too lean...especially for a modified 12 engine!
In the December 03 Cycle World, Kevin Cameron's page refers to the correct or ideal a/f ratio to make the most power........12.5-1. Both mrsantafe and I are in the 12.7-12.8 range......
Also, think about this.......Pipe manufacturer's do not use a dj250 to develop pipes! There is a good reson for that.
I and many other's out here in Phoenix have had EXCELLENT results on the MJP Dyno. It is an "Engine Development Dyno".
Recently, mrsantafe came out to Phoenix w/ some friends to have his 2003 12 tuned on the MJP. He has the "Carpenter 1290" kit in it. The best his tuner could get on the dj250 was 186h.p. (this result was after a 6 hr. session!!) The baseline run on the MJP was 189. After giving it the proper a/f (Lot's of gas!!)...He ended up w/ 202.5 !!
(See more details of this at (www.susukihayabusa.org) the "Best Tuning Dyno?" thread on page 4). The most noticeable results were how much the engine smoothed out and ran cooler after getting the NEEDED fuel to it.
I also had very similar results....My baseline run w/ the Muzzy 1270 kit was 185.5 h.p. and 103.3 ft.lbs. That was with a map made at Dyno Jet in Vegas. After the 2 hr Tuning session, I ended up w/ 202.4 h.p. and 111.4 ft. lbs. There is no voodo science here, and even if you don't belive the actuall #'s......look at the difference between them.
At the drag strip before the 1270...
(try not to snicker...I am not a 60' god and I weigh 225 w/ full gear)
I would run 10.25@141.79 w/ a 60' 0f 1.846.
After the 1270 tuned...
10.04@ 150.77 w/ a 60' of 1.865
My best ever was 9.90@146.34 w/ a 60' of 1.753 (rare indeed and they kicked me out that night due to not having an NHRA licence!!)
Let me remind all of you that I am not "BASHING", I am trying to let you all in on something that is for real and it WORKS! I've spoke of this before and have received plenty of heat for it. You can check out the MJP at (www.mjpeng.dk) and check it out for yourself.
The biggest difference between the two dyno's is that the MJP can Measure h.p. and tq. while the brake is on (engine loaded) and you can see what adding or taking away fuel does to power REAL TIME. You don't have to back out of the tuning program to do a "Blow Through" Inertia run to see where your power levels are at. This is HUGE in many ways!
Food for thought Gentlemen............
Cowboy
posted December 02, 2003 08:23 AM
Wouldn't adding cc's mean you need more fuel?I'm a bit confused as to Jimp saying the bike is running real rich without a pc3?
I ask because the map i got from Vincent made real good power in my bike at stock bore and its getting the mtc 1286 kit installed.I'm wondering if i could just add a couple points to each column?
psycho1122
posted December 02, 2003 08:26 AM        Edited By: psycho1122 on 2 Dec 2003 08:29
With the 1270 Muzzy kit....It's more about the added Compression than the cc's. Cam Timing also play's a part.
These engines like it a tad richer at the torque peak and a tad leaner at the H.P. peak.
Also, these high compression engines run great on pump gas if the a/f is correct.
Hells Dark Lord
posted December 02, 2003 09:39 AM
interesting....have to keep that in mind when I go to put in the 1270 kit next fall.....
BA
posted December 02, 2003 07:51 PM
I'd have to agree that the ideal ratio is in the 12.5 - 12.8 range for our bikes.
Also, you do not have too much oil. Your concern is valid about the crank losing HP due to windage, HOWEVER, the 12R crank is not close enough to create that windage problem like a longer stroked engine might have. (ie. a Hayabusa)
Proven on the dyno for both the 12R and the Busa.
jimp
posted December 07, 2003 05:24 AM
I installed the PC3R, changed the oil to MTX4 10W40 and corrected the level. The best run was 195.5 X 110.2, we found out the motor likes timing at 12.8 A/F.
Where's my 14 ???
mrsantafe
posted December 07, 2003 06:07 AM
You should try the mjp dyno for sure. My bike best 186 hp with carpenter 1290 kit headwork, bigger cams, step hindle etc. This on a dyno jet 168 in albuquerque new mexico.
Took it to NVH in phoenix
results:
baseline- no tuning 189 hp
after- 202.5 hp- big horsepower gains because the bike ran so lean 13.8-14.0 and after a/f were around 12.5/12.8
Take a close look at the differences here!! 13.5 hp WOW!!!
I was very sceptical that one dyno could be alot better than the next,I have spent hundreds of dollars and several customs map trying to eech out every horsepower.Well that final number was 186hp. Gee I thought to myself I just spend alot of money for a supposed 203 hp. Thanks to psycho1122 and his coaching sessions I figured what the heck it's only a little more money. In either case I finally have peace of mind. Man!!! do i have peace of mind now. Bike runs smoother, stronger and is better in everyway.
Before I had my dynoed in phoenix i raced a friend of mine in 6th gear roll-ons. His bike is geared slightly shorter. Everytime and didnt matter who said go first his bike would pull on me about 3 1/2 lengths. When i got back we re ran and all of the sudden i'm right next to him and in fact i am now begiinning to pull on him!
I still need to get my bike back to the drags and see what improvements I got here.
My best et to date is 9.95@142-143 mph with 1.59 60ft I really expect to pick up 2-3 mph gain in the quarter!!
2006 ZX14 gone
2004 zx10r (her race bike)
2002 ZX12 (still kicking a--)
2007 gsxr 1k (race bike)
zx12haitian
:APB: BLACK MAN SPEEDING
posted February 08, 2004 03:13 PM
well the frist time i dynoed i was scared b/c it was at one of our bike meetings and there was this really nice busa before me and he did a 149 max speed like very low, so next it was me and so i get the print out and i did a 175.6 dont rember the max speed and that was the day i got scared of my bike. oh and also all i have is a p/c and muzzy full and k&n . with. get this 23K on the bike
zx12haitian
posted February 08, 2004 03:14 PM
and that was on 93 i want to dyno it on 101
Rac4IT
Bergie
posted February 08, 2004 06:08 PM
My stock '01 made 180.3rwhp x 100.4 rwtq with nothing absolutely NOTHING but a hindle pipe. All stock including stock filters! 93 pump gas and no advancer no powercommander! http://www.dontbescaredracing.com/dyno/0503_silverstock01_hindle.jpg
0.24556088447571 seconds processing time
