BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Gearbox noise???? NEW TOPIC NEW POLL POST REPLY
TripodMeat
posted December 16, 2001 04:18 PM
Gearbox noise????
As I accumulate more miles ( 1200 now ),
I am noticing that I will miss gears once in a while,
and I get ALOT of noise ( also while shifting normally,
seems to be louder than at first.....
Anyone have any thoughts on this???
12RPilot
posted December 16, 2001 06:25 PM
Is this constant noise or the clunk while shifting?
NESBA #209
TripodMeat
posted December 16, 2001 07:31 PM
The "clunk" while shifting....
It seems to louder than it was...
silver01bullit
on here too much
posted December 16, 2001 07:55 PM
I've noticed the same thing with mine at times. Are you using the clutch when you shift or not? If you use the clutch it may be how the clutch is adjusted. Make sure there is some free play at both ends of the cable.
  Ignore this member    Click here to send silver01bullit an AIM message.
0.26616215705872 seconds processing time
