BIKELAND > FORUMS > ZX12R ZONE.com > Thread: HEAD LIGHT TROUBLE NEW TOPIC NEW POLL POST REPLY
tccycles84
posted October 12, 2003 10:31 AM
HEAD LIGHT TROUBLE
WELL HERE WE GO AGAIN I HAD THIS PROBLEM BEFORE SPENT $90.00
AND NOW I HAVE THE SAME PROBLEM! HERE WHAT IT IS ? I HAVE A 2002 ZX12R THE HEAD LIGHT ARE OUT IN HAVE CHANGED ALL THE RELAYS AND J BOX. THOUGHT THE PROBLEM WAS FIXED TILL I WENT RIDING TODAY. HALF HOUR OUT MY BUDDY TELLS ME I HAVE NO LITES UP FRONT. AS ANYONE ELES HAD THIS HAPPEN SO WE HAD TO CUT THE RIDE SHORT TO GET IN BEFORE DARK. ANYWAY ANYBODY HAVE AN IDEA OF WHAT IS THE TROUBLE WITH THIS P.O.S. I AM IN GERMANY WITH NO DEALER SUSPORT
Hells Dark Lord
living life, and loving it.
posted October 12, 2003 10:34 AM
cant help you TC..only headlight problems I have had with my 02 were that I kept blowing bulbs.....i was using super white high output bulbs, had to down grade them a bit...now they are fine....
frEEk
posted October 12, 2003 10:45 AM
u may have done this already (can't tell from what u wrote) but there is a fuse for the headlights by the bettery too. sounds like you have already checked the fuses in the main fuse box, but chec the extra one by the battery. that has been the problem for most folks.
zx12richard
The Green Monster..
posted October 12, 2003 11:29 AM
You check the headlight plugs and see if they are melted mine did and blew the main fuse by the battery....
posted October 12, 2003 12:12 PM
are you running high(er) wattage bulbs?
tccycles84
posted October 12, 2003 12:15 PM
no , i run stock bulbs and i have checked all the fuses to inclued the ones in the battery box all are good. all plugs are good and the relays all check good.
posted October 12, 2003 12:47 PM
Are the lights non functional with the fuse intact or is the fuse going?
have you metered at the sockets for power? other thing to do would be to meter at the switch as well...
is your bike not under warranty? do you have any bizzarre additions? alarm, heated vest etc...
you should also check the wiring harness for damage... check the pinchpoints under the tank etc and also where the tray is sliding in.
Sagot had an intermittent prob with his SV650.. turned out to be a screw from bodywork putting pressure on the wiring harness.
1bad12r
posted October 12, 2003 12:57 PM
I had a prob. with mine. But it was the J.box. The dealer told me that Kawasaki had a bad batch of J.boxes that got out by mistake. It took them 2 boxes to get it fixed.
768 Ryderz
tccycles84
posted October 14, 2003 08:08 AM
I have not add stuff i have replace the j box one time it worked one time then quit. i have no power at the plug and have yet to blow a fuse anywhere on the bike all bulb are good . still no lites
frEEk
posted October 14, 2003 10:11 AM
sounds to me like u'll have to trace the problem backwards from the jbox. u dont have power at the lights, but do u have power at the relay output? input? jbox output? jsut keep testing points in the system till u know between what 2 points it's failing.
0.23988914489746 seconds processing time
