wannabe
posted September 24, 2003 10:14 PM
Yellow box or bonneville box?
OK, I've been running 16/48 gearing at the dragstrip on my 2001 all season. (with a bar and slick) I've just about got my air shifter dialed in. I typically hit the traps in the 1/4 at around 144 mph. Now that I don't have to worry about foot shifting, I can drop my gearing even lower. I'm thinking that I'm going to start with a 16/52...mostly because I already have the 52 sprocket. I'm being told that 16/55 is the way to go.
I just thought about an issue. I'm currently running without a yellow box or a bonneville box. It hasn't been an issue because the 16/48 gear ratio still makes the limiter kick in at 158.4 mph (186 mph indicated.) Since I only go 144 in the 1/4, it hasn't been an issue. But, when I go down to 16/52, my calculations tell me that the limiter wil kick in at 146.3 mph, and 138.3 with the 16/55 gearing.
I know that I can get around the limiter issue at the dragstrip with either a yellow box or a bonneville box. Which one should I put on the bike?
Here's the prices from Schnitz:
Yellow box - $119.95
Bonneville box - $89.98
This is what I figure:
Yellow box: More expensive, but it will make the mileage number on my bike more accurate. Harder to install than the bonneville box.
Bonneville box: Piece of cake to install and cheaper than the yellow box. Odometer will rack up mileage like there is no tomorrow.
What do you guys think I should do?
