BIKELAND > FORUMS > ZX12R ZONE.com > Thread: "OOPS"! A problem and a Question? NEW TOPIC NEW POLL POST REPLY
posted September 23, 2003 06:39 PM        Edited By: VincentHill on 23 Sep 2003 19:47
The Oops is, I was aligning the Injector and (What else), it broke! The Lord takes care of Babies and fools, I carefully drilled out the the piece and then for the first time ever, an easy out got it out! I used a drill in reverse to remove a few threads and messed them up and found the exact tap I needed and ran it through all of the stacks.
Now to the question? Shouldn't the injectors be in the airstream more? Do they have longer injectors? I need to know right away
This is what I mean about the distance the Injector sits!
[/img]
If I need to get new injectors, at least I still have the time to do it!
Randall has this style of Injector at work! Is this what I should be using??
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: \"OOPS\"! A problem and a Question? NEW TOPIC NEW POLL POST REPLY
0.21612501144409 seconds processing time
