BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Increased Cooling Capacity NEW TOPIC NEW POLL POST REPLY
ZCatDude
posted September 22, 2003 08:48 PM
Has anybody tried to have the radiator capacity increased by a new , more efficient core replacement - more rows, fins or any other method? In Tennessee summer heat, the 12 can run damned hot, specially in slow traffic. I run Engine Ice, but am looking for more help. Anybody have any experiance or thoughts, suggestions??????
posted September 22, 2003 11:54 PM
if you find a core replacement which is substantially more efficient than OEM, a bunch of folks will follow yr lead. Keep looking!!!
frEEk
posted September 23, 2003 12:24 AM
the midget car guys say u can get a custom rad made up for around $300. i woudlnt mind doin the same with the 12. it runs real hot even in the mild weather around here, and that's with a bone stock engine! cant imagine what the boys with the 1361's do.
posted September 23, 2003 02:39 AM
Earls would probably have something that would work. Or fit an old cooling fan from another sportbike onto the radiator.
ZCatDude
posted September 23, 2003 03:59 AM
frEEk is right about the 1361 motors, they gotta run extremely hot.
As long as the 12 has been around, I was hoping that someone might have tried to modify a radiator already. Of course Kawasaki put an extra fan on the newer model 12's and I'm sure that helps, but I gotta believe more cooling surface would be even better. Reduced heat = HP, Muzzy or one of the vendors could probably sell a boatload of modified systems!!!!
Doug, any comments?
EastBayDave
posted September 23, 2003 09:10 AM
...anyone done an oil cooler yet? NO, I'm not talking about that thingie around the oil filter. I'm talking Earl's Supply, ZX11, or similar...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
k bryant
Sponsor
posted September 23, 2003 11:50 AM
Stock motor'd '03. But run in lot's of hot weather in SoCal, as well as stop & go. Between the dual fans (alum/Muzzy) & Water Wetter, the fans hardly ever turn on. Just seems to be really effective. I think the aluminum fans may be a little more efficient than the stock plastic ones as well.
EastBayDave
posted September 24, 2003 06:40 AM
Yeah I got the Muzzys (single) fan & Water Wetter. It seems to run much cooler w/the guage now at 8-9:00 instead of the old 10-11 (& fan used to run a lot.) You can feel the wind coming out the side vents much stronger now...
It hardly ever runs now except the hottest days @ stops...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted September 24, 2003 07:17 AM
Make sure your coolant isnt mixed too rich. Typically 30% coolant is more than enough. The rest should be distilled water and a water additive...like Water Wetter, etc.
Also wiring a switch paralell to the fan sensor.. so you can turn the cooling fan(s) on at will. Dont see a need to spend $300+ for a custom radiator.
kawachan
posted September 24, 2003 07:33 AM
Freek, my mech had one made for his dwarf and now uses a factory one. It is lighter and VERY capable of cooling a 12, even one run almost wide open for minutes at a time.
RED NINJAS RULE!!
your car is slow
Fuck Nitrous...Got Boost?
posted September 24, 2003 11:01 AM
wow...10 to 11? I ride in hot as hell florida and ive never seen above 9 when moving.
ALways sits at 8 at highway speeds.
I use pure distilled water and water wetter.
Do not taunt happy fun ball!
BA
posted September 24, 2003 02:49 PM
I think since I've lowered my bike on the tree's that I'm basically shooting myself in the proverbial foot. The top part of my radiator basically doesn't get any air flow.
your car is slow
posted September 24, 2003 03:36 PM
mines down 1" in the front too.
posted September 24, 2003 03:40 PM
BA... wire a switch for your fan. The sensor is right inside the fairing vent.
aliveagain
posted September 24, 2003 05:24 PM
you may want to try a foam cleanser on the coils just to maximize heat transfer.Dirty coils slow down air flow.And make sure no bugs bent over some fins.
ZCatDude
posted September 24, 2003 09:23 PM
Wish the 12 had a digital temp readout like some of the new bikes. Engine Ice did help some and also the fan over-ride switch helps, but my concern was for a bigger bore motor I'm thinking about. I'm surprised that nobody has tried the "enhanced Radiator" approach, but most with larger motors seem to get by OK. Anybody else with a bored & stroked 12 have any input?
posted September 24, 2003 11:57 PM
...Anybody else with a bored & stroked 12 have any input?
i have a 1427, use water wetter & distilled water. No problems with over heating, BUT gotta be careful to remove trapped air bubbles from the coolant system.
My method for removing air is to have the bike on a rear stand, idling, pour in the coolant slowly as the bike starts to warm up, when full & no more bubbles coming to the filler opening; cap it. Then idling and lite blipping let the system heat up and pressurize.
I disconnect the fan connector and let the temp get up to 11pm. At this point the coolant is HOT and is expanding into the overflow bottle. I reconnect the fan and even put an external fan on it and the temp comes down quickly to 9m and I shut the bike off. When cool, the the coolant gets sucked back into the engine/rad, and air bubbles are GONE. Sometimes it takes 2 cycles to get all the air.
SAFETY MOMENT!!!!!!!
Last Sun I was heat cycling the bike as above. Temp was at 11pm and I leaned over to snap the rad fan connector together, and WHOOSH! A rad hose connector let go on the l side and drenched my legs in HOT coolant/steam. Of course I was wearing shorts... I'm a dumbass... A red legged, oozing, peeling, limping, dumbass...
posted September 25, 2003 02:36 AM
Ah.. you can buy one of those guages for under $100 complete. Any roadracing supply store like Marietta Motorsports or Kneedraggers.com would stock this item.
0.22922396659851 seconds processing time
