BIKELAND > FORUMS > ZX12R ZONE.com > Thread: air shifter question NEW TOPIC NEW POLL POST REPLY
wannabe
posted September 04, 2003 06:52 PM
OK, so I'm installing my air shifter this weekend. I've got just about everything figured out except where to mount the solenoid. I am being told to make sure that the air line from the solenoid to the air ram is as short as possible....preferable about 6". That would mean that I have to mount the solenoid on the frame somewhere.
Anyone here running an electric over air setup on a ZX-12? Where did you mount your solenoid?
1bad12r
posted September 04, 2003 09:55 PM
put mine under the first seat !
768 Ryderz
lonniemac
posted September 04, 2003 11:05 PM
i just got mine operating properly. i built a bracket to mount mine going forward to the water pump. spencer cycle has a very nice bracket system for this application. it is true about the electric solenoid being close to the ram thats what my problem was . i had the sol. under my seat. at first .with the ram mounted this way you need a lot of pressure i use 160 psi. i have the co2 high pressure with the spencer cycle adj. regulator . its the bomb for this setup.
0.30175614356995 seconds processing time
