BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Valve Adjustment Question NEW TOPIC NEW POLL POST REPLY
n da zone
posted August 28, 2003 06:57 AM
Bike is going in to the shop for the 7,500 mile valve check.
Do you normally recommend replacing the valve cover gasket? I had the shop order one anyway, thinking it is a 'consumable' item.
I didn't want my bike doesn't site there for 4 days waiting for it, but I got to thinking that maybe it is reusable?
Just don't want no stinkin' leaks.
RAC4IT
Bergie
posted August 28, 2003 07:12 AM
I've reused them before, no problem. Depends on the condition of the gasket when you pull the cover I guess, some fair better than others. Doesn't hurt to have the replacement on hand that's for certain.
Zx23rr
Mahogany Bomber Pilot
posted August 28, 2003 07:50 AM
on my zx-11, after 80,000 kms, still have the originals. you decide. If it leaks, it's your problem. If they use new and it starts to leak, its their problem!!
ScaredyCat
posted September 04, 2003 03:38 AM
It's the standard Kawa rubber camcover seal right?
Somebody shoot me down, but I thought that these things were designed to be compressed only as far as the cover-bolt threads would allow, and they are designed to be re-used...?
It's not getting deformed, so it shouldn't need replacing as long as it isn't perished or cracked..... Well, that's what I always thought.
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
your car is slow
Fuck Nitrous...Got Boost?
posted September 04, 2003 06:37 AM
Mine leaks after I checked the valves....minor..but annoying.
Do not taunt happy fun ball!
posted September 04, 2003 06:57 AM
Not a part that needs to be changed unless damaged by an inept technician. The crush is preset (as scaredy points out). I don't think I've ever changed one out that has been in use.
Doug
n da zone
posted September 04, 2003 07:28 AM
OK. Thanks. I'llsave the $38 and tell them to not replace it.
your car is slow
posted September 04, 2003 09:16 AM
Ive removed the cover about 3 times since it started leaking....the gasket looks frikkin fine...Im about to RTV it
0.22079515457153 seconds processing time
