MarkZX12RKX500
posted August 25, 2003 10:55 AM
Hesitation very close to gone!!!
set the throtle sensor 1.087, using the pcIIIr map on their web site and leaned the low 2 notches can't even feel it if I clutch a little differant.
Still can feel it a little without clutching diff.
what happens if it's leaned to much at low?
JoshDunn
posted August 25, 2003 11:52 AM
Are you happy with your Muzzy? I am soon in the market for a pipe if it's worth it. Thought the Hes./idle thing would make a muzzy not worth it. I want a fairly inexpensive set-up though otherwise I think I would go Akro.
Yosh Tri-Oval, PCIIIUSB Tuned by Nels
jonwright
posted August 25, 2003 12:34 PM
Stumble not a big deal if you don't do a lot of traffic light/stop/go stuff.
Let your beat run free on the open range in its natural habitiat!
MarkZX12RKX500
posted August 25, 2003 11:32 PM
Edited By: MarkZX12RKX500 on 26 Aug 2003 00:33
Yes I like it,the sound is killer.
Well I got the full titianum for $980.00.You can get the titianum/stainless for around $700 or a slip on cheaper if you don't want a full.
The full titinum is light as hell at least 30lbs lighter than stock if not more I should weigh the stock pipe just to see.
posted August 26, 2003 04:17 AM
I still cant believe you guys dont like the idle with the Muzzy Pipe. It is freaking awsome!! just the looks and people coming over and saying oh man that thing sounds so bad ass!! I had a Full Ti before I put my sidewinder on and Muzzy Rocks!
Mad Mike
MarkZX12RKX500
posted August 26, 2003 05:13 AM
I too like the idle sound just not the Hesitation at 2300-2500 rpms on take off.
JoshDunn
posted August 26, 2003 08:39 AM
Does the hesitation problem outweight the performance and sound though?
Hells Dark Lord
living life, and loving it.
posted August 26, 2003 03:00 PM
should have that map out in a few....Mark......Do ya still want to check it out?
Zx23rr
Mahogany Bomber Pilot
posted August 26, 2003 03:11 PM
If you guy's have a pc3r, you can help limit, lower, or eliminate the hestition if you advance the timing in the 0-60, 2000, 2500, 3000 RPM range. Add 5 over what you have now, and take 1 or 2 degrees out as the rpm and throttle setting increases. You would be amazed at how much timing you can put in at this low RPM. Of course this is on a stock mill on the inside. No extra compression etc. (you probably could, but the numbers would be less. Does this make sense, i didn't think so!
JoshDunn
posted August 26, 2003 03:43 PM
Are there differences in the hesitation between 2002 models and 00-01 models. Is one year more forgiving? Etc. Etc. you get the idea?
