BIKELAND > FORUMS > ZX12R ZONE.com > Thread: parts 411 or spencer cycle for exhaust? NEW TOPIC NEW POLL POST REPLY
JoshDunn
posted August 24, 2003 09:49 PM
O.K. i know spencer cycle supports this site but justify the higher exhaust prices? Who knows where I can get a hindle cheap? Muzzy might be O.K but I am scared of the lower RPM problems that I have read about, for a mostly street ridden bike that is most important.BTW I am almost more concerned about looks and sound than total top-end so try to talk me out of buying a slip-on(I was kind of thinking that would be the cheap,easy way to go. SO SORRY FOR THE NEW EXHAUST THREAD I DID LOOK AT ALL THE OTHERS FIRST.
Yosh Tri-Oval, PCIIIUSB Tuned by Nels
posted August 25, 2003 07:10 AM
Of course Spencer Cycle..... This site wouldnt be around without their support (and that's the truth)..... He's a top notch guy.
jonwright
posted August 25, 2003 07:49 AM
Go with someone you trust. I've seen/heard of guys getting screwed by the cheapest they could find.
Parts 411 has no affiliation with our hangout. Although I've always purchased from my local dealer, I'd choose Spencer over 411.
posted August 25, 2003 01:14 PM
i've always gotten the cheapest prices from Doug at Spencer. Are you sure you are comparing apples to apples?
posted August 25, 2003 01:43 PM
Speak to TurboBlew! A friend of mine just bought a new Step Hindle and rode the bike 15 miles before he crashed (On the left side, so the Hindle is mint!) It is stainless and the can is Ti! He wants $585. Steve said he wants to buy it, but I am not sure if the Timing is right (Steve may have planned to buy it later, but the deal made him do it earlier)! Send him a PM!
Ask Vorizn about what he went through to get a pipe for $650.00! in the end, it even cost "ME" a few dollars and it sure cost him time and a lot of phone bills! The dealer's cost (Depending on if you get Ti or CF, is between $600 and $725. Now tell me about someone selling theirs for $635 to $695? They cannot make any money, so if there is a problem, there is no one to go to! Doug sells his (Again depending on the muffler) for between the very low $7's (Aluminum Muffler) to very low $8's (CF Muffler) and of course a little above the Mid $7's for Ti muffler (At least this is what I think he sells them for! Would you sell them for less?? (remember he offers other services also!) Ask Voz if he would go for the "Deal" again!
(I am not kidding when I say that It cost me some time and money also!)
JoshDunn
posted August 25, 2003 01:51 PM
My bike is an 02, I noticed some companies sell different pipes for 02 some just list them 00-02 whats up with that?
JoshDunn
posted August 25, 2003 05:41 PM
QUICK, I have a chance to get a good deal on a stainless bolt on Muzzy, What are the disadvantages Of just a slip-on
necro
My Grandma Is A Virgin
posted August 25, 2003 07:15 PM
Don't forget the fit issue with the Muzzy either.
jonwright
posted August 25, 2003 07:51 PM
My Muzzy fit perfectly. No probs, no melted fairings.
Slip on doesn't save much weight - I felt my bike handle differently. Yes, I did. Saved 15 lbs.
Major difference between full and slip on is weight. On some of the other bikes it's probably not worth it. On the 12 it is. Not sure about HP difference, though. But for the weight it's worth it to me.
necro
posted August 25, 2003 08:23 PM
They much've fixed it.
MarkZX12RKX500
posted August 26, 2003 05:23 AM
Hindle probley has the low rpm problem too. I mean why wouldn't it unless there is a cat in the hindle, NOT!
Hells Dark Lord
living life, and loving it.
posted August 26, 2003 05:54 AM
my muzzy fit perfectly...no melting...the melting came to be when guys started bolting the pipes for tha tA model bikes on the B model bikes...the fairings were different shapes and the pipe was too close to it. As for the low speed hesitation....a good map will all but get rid of that.....I ride my 02 all the time...I have 13000 miles on it, and spent 11 months in the desert....runs strong....no hesitation.....buy a Muzzy....by it from Muzzy, or from Spencer, but go with someone who you know has good customer service.....there is no substitute, or price that can be put on customer service.....JMO......Jim
posted August 26, 2003 07:08 AM
There are post about the Hindle and Bottom end! From Idle to peak, it is like a Have a Reostat not a throttle!
JoshDunn
posted August 26, 2003 08:33 AM
I have read most of the exhaust threads but I still don't understand why one free flowing exhaust would run so much different than another? It seems Akro and Step Hindle are best for bottom end and all around drivability. I even read that starting problems with a Muzzy can be cured by plugging off the end of the pipe when starting cold, Creating a little backpressure. It seems that header design actually makes a big diff. not just pipe size. the 12 comes with a pretty nice exhaust sytem factory(I have seen much worse) You would think a slip on would give you almost as good Performance but leave you with some weight(By the way, if the factory headpipe is Stainless why does it weigh so much more than say, a Muzzy?)
jonwright
posted August 26, 2003 10:01 AM
I don't have to do any of that crap with my Muzzy system. I'm quite pleased with it.
Basically I suppose Muzzy uses much lighter and thinner header pipes to make them lighter than stock. That also probably contributes to the noise which I would imagine stock pipes are trying to beat.
I was concerned with everyday drivability with doing mods to the bike but I think it's just different, not a burden.
JoshDunn
posted August 26, 2003 02:43 PM
Cool man thanks for the input. I am going to try to holdout for a system, but I am poor right now and can get a bolt-on for maybe 200.00
claude
posted August 26, 2003 04:59 PM
OEM collectors always have been double walled so I assume it is the same for ZX-12R while after-market ones are single walled.
posted August 26, 2003 05:03 PM
Josh... I know of a nice full system for sale for $450. Ti muffler too!
Email me
jonwright
posted August 27, 2003 04:23 AM
Dood. Killer bargain - assuming it's in good shape.
posted August 27, 2003 02:39 PM
... It seems Akro and Step Hindle are best for bottom end and all around drivability. I even read that starting problems with a Muzzy can be cured by plugging off the end of the pipe when starting cold, Creating a little backpressure. It seems that header design actually makes a big diff. not just pipe size. the 12 comes with a pretty nice exhaust sytem factory(I have seen much worse) You would think a slip on would give you almost as good Performance but leave you with some weight(By the way, if the factory headpipe is Stainless why does it weigh so much more than say, a Muzzy?)
This sounds like ZX-12.org info. I had a Muzzy on both a 2000 and 2002. Never had any "drivability" problems... Uh I take that back. The 2002 needed Muzzys map to cure some low end problems. Available for download from Muzzys.
Brought an Akra to see if there was any difference in top speed. The Akra needs alot more fuel (like 30% more) in the 100% throttle range for WFO.
JoshDunn
posted September 04, 2003 05:05 PM
I just thought of something......If you get a map from muzzy they are at a couple thou. above sea level. I am at Sea level, how does that work?
JoshDunn
posted September 04, 2003 05:12 PM
I want to get a new post on exhaust sytems and stuff going because most of the info in the archives is old and I'm afraid things have changed for the new bikes.
JoshDunn
posted September 04, 2003 06:34 PM
I think I will just keep this on top
JoshDunn
posted September 04, 2003 06:36 PM
Has anyone put a bolt on muffler on there bike and not swapped it for a full system shortly there after.seems to be the way it goes.
JoshDunn
posted September 04, 2003 06:47 PM
Is everyone totally fed up with the exhaust threads or what?
0.22259306907654 seconds processing time
