BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 12 Dyno Question NEW TOPIC NEW POLL POST REPLY
jimp
posted August 23, 2003 09:49 AM
12 Dyno Question
Taking the 1290 Carpenter for some dyno runs next week, how do you get the torque reading, is it their a wire you hook on to? Also is better to remove all the side panels And what is the consistence on a good A/F ratio
Where's my 14 ???
posted August 23, 2003 10:17 AM
1. You need to hook an inductive lead over the wires to one of the stick coils.
2. Yes, remove both lowers
3. Good is 13.4:1. Some motors run better with richer, some leaner.
k bryant
Sponsor
posted August 23, 2003 11:14 AM
On the 12, you really just need to remove the left facia panel that connects the fairing to the gas tank skin. You can get to the wire from there easily to get a torque reading.
Personally, I shoot for a 12.8 - 13.4 reading. With the leaner reading more on top end/wfo. JMO
posted August 23, 2003 01:45 PM
if yer doing a full dyno tuning session (2 hrs +), yes indeed take off the fairing lowers. If just a few pulls, I wouldn't bother pulling them.
You can also get a tach pulse from an ECU lead. Works fine.
posted August 24, 2003 12:43 PM
My bad, ya the black wire from the ECU works great.
RAC4IT
Bergie
posted August 24, 2003 02:22 PM
Its so funny to hear people talk about air fuel ratios "what's the best a/f ratio" etc you tune your bike for whatever makes the most power every bike is different. When all is said and done you should have checked if more fuel and less fuel makes more power across the board against your final number. Anything else would be less than scientific.
jimp
posted August 24, 2003 05:24 PM        Edited By: jimp on 25 Aug 2003 08:52
I'm looking for a starting point, thats why I ask for a consistence,da.
Where's my 14 ???
psycho1122
posted August 25, 2003 06:44 AM
Excellent point RAC4IT. That's why the MJP (and others like it) do such a good job of setting up A/F. It can determine max h.p. and torque while the break is ON. You can adjust your a/f on the fly and see on screen if your h.p. and TQ rises or falls real time.
If you are running a high compression big bore 12, something under 13.0 should keep it smooth and happy on pump gas.
0.21442794799805 seconds processing time
