BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Muzzy clutch plates NEW TOPIC NEW POLL POST REPLY
johns
posted December 09, 2001 09:42 AM
Muzzy clutch plates
Does anyone know which Kawasaki model and year the fibre plates come from that Muzzy is using for they're ZX-12 clutch?
2006 ZX-14 (sold)
2012 ZX-14R (Brock's Perf. project bike Louisville Slugger)
2013 Honda VFR1200F
2003 124 C.I. H.D. Super glide
posted December 09, 2001 10:41 AM
they are Y2000 (prob other years too?) stock fibers and 2mm steels 10+10, the the other fiber also a stock fiber which goes closest to the engine side (the one skinny fiber) rarely goes bad. Gettem at Ron Ayers, 40% off what Kwak sells em at.
posted December 09, 2001 02:06 PM
yes entropy is right go to ron Ayers! cheeper then muzzy's also. but I dont use the small fiber on the inside, I just use a regular fiber and seems to work good.
mad mike
wilson1
posted December 09, 2001 03:27 PM
fiber plates
has anyone used barnett kevlar plates ¿¿
ucp
posted December 09, 2001 04:00 PM
i tried barnett plates they grip good but slip them one or two times they are history
NINJA12
posted December 10, 2001 09:56 AM
how much does Ron Ayers sell a clutch pack (11 fibers 10 steels) ?
posted December 10, 2001 11:57 AM
about $160
NINJA12
posted December 10, 2001 08:02 PM
That is good, i make put a spare set on my christmas wish list.
SpencerCyclecom
posted December 11, 2001 06:56 AM
One thing you guys should know is the Muzzy clutch kit gives you a different STACK height which enables the clutch to work smoother and you to use it better. The mods they do to the inner hub allows this along with the springs. just though you might like to know.
Doug
SpencerCycle.com
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
johns
posted December 11, 2001 03:35 PM
thanks for the information guys. how do i contact ron ayers to order plates? doug i assume when you say the inner clutch hub( muzzy part ) was modified for more or different stack height that they machined the hub to accept the thicker steel(2mm)plates. does this machining also provide more clearance between the steels and fibres than stock when the clutch is disengaged?
2006 ZX-14 (sold)
2013 Honda VFR1200F
wilson1
posted December 11, 2001 03:46 PM
Muzzy cluch
Muzzy machines hub to provide more oiling the different stack height comes from using one less friction plate and one less steel plate
harryzx-12
posted December 11, 2001 03:48 PM
http://www.ronayers.com/main.cfm
johns
posted December 15, 2001 04:19 PM
thanks for the address for ron ayers harry. do any year zx-7r mirrors fit the zx-12? tried to order the magical racing mirrors but could't figure out how to transmit the fax form order on they're site (i am computer illiterate). they are beautiful mirrors and if i can't figure out how to process a secure order i guess i will settle for the zx-7r mirrors.
2006 ZX-14 (sold)
2013 Honda VFR1200F
0.27369499206543 seconds processing time
