BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12r cylinder needed NEW TOPIC NEW POLL POST REPLY
Grinder_Smith
posted August 16, 2003 09:18 PM        Edited By: Grinder_Smith on 16 Aug 2003 23:17
ZX12R cylinder needed
Greetings!
I need one ZX12R cylinder block in any condition. I'm going to cut it into sections for engineering purposes, so one with a connecting-rod through it or a section sawed out would be perfect.
What do you have?
I'll pay what ever seems fair plus shipping to Arizona 85251.
Thanks,
Grinder
I am designing a 3749.551cc 60* V-12 engine.
jonwright
posted August 16, 2003 09:19 PM
Holy SHIT! Keep us posted on how you do with it. Curious with the rest of the gear heads out here, I'm sure.
Grinder_Smith
posted August 16, 2003 10:09 PM
"Gear heads"?
I have designed a center gear-drive power take off, just the same as in certain older grand prix cars with inline eight-cylinder engine.
I effect, each four cylinders - a virtual 1250cc Ninja engine - is only turning 1/3 the mass of this gear, the clutch, and so-on.
The Kawasaki - which ever ZXxR model it is - is generally referred to as, "peaky", or, "likes to buzz". Hey, I like that!
I found a six-speed transmission, the Richmond Over Drive (ROD) that allows me to choose the ratio of _each_ of the six gears. Well, 5 is direct. Alright, cool. Oh, I got the ratios so close - right out of the catalog - that I can really keep the engine buzzed.
From 12,000 RPM in 1st, the R's drop to 8,142 in 2nd. The higher gears, the faster gears, the more highly loaded gears? - the have closer ratios.
This will work?
A 4-1/2" Quarter Master light weight circle track car twin-disk clutch keeps the rotating mass way down.
At higher RPM, retarded intake camshafts, maybe via a timing unit as on a Ford Escort(!) would let the Ninja heritage really wrap out tightly.
This is what I think about . . .
Grinder
0.23462700843811 seconds processing time
