BIKELAND > FORUMS > ZX12R ZONE.com > Thread: LOOKING FOR A FULL EXHAUST SYSTEM FOR AN 03 ZX12R NINJA, ANY SUGGESTIONIS????? NEW TOPIC NEW POLL POST REPLY
ZX12R NINJA
posted July 25, 2003 04:36 PM
I have a 03 ZX12R Ninja. I still have the stock exhaust on it. I do more street riding than time at the track. I want to get a full system; do you all have any suggestions? If, so what kind of gains would I get?
jonwright
posted July 25, 2003 08:28 PM
Dood. Do a search as there are posts ad nauseum out there.
We've all done the 'pipe wars' discussion - lot's o' bits and bytes out there.
saltire
posted July 26, 2003 12:10 AM
1 st choice = Akra
2 nd =Muzzy
3rd = Micron Serpant.
  Ignore this member    Click here to visit saltire's homepage.
posted July 26, 2003 05:55 PM
Best pipe out there is the Akrapovic!!!...Just over $900.00 from www.Spencercycles.com
vozizm
Got Nothing Witty To Say
posted July 26, 2003 06:19 PM
Hindle Step System...
EastBayDave
posted July 26, 2003 06:26 PM
I run an Akra for now, but lots of folks like Muzzys....loud & quiet baffle options...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
Hells Dark Lord
living life, and loving it.
posted July 26, 2003 08:54 PM
I run a Muzzy, but you need to check that new Micron serpent out, its badass.....and much cheaper than the Akro
jonwright
posted July 27, 2003 09:00 AM
Well, here we go again!
I have the Muzzy with quiet baffle. Like it pretty well.
Megabyte
posted July 27, 2003 12:13 PM
You won't be sorry with a full AKRA system. I've had mine for two years, and haven't yet seen one I'd swap it for...
ZX12R NINJA
posted July 27, 2003 02:59 PM
Thanks for the info gents, this gets me in the right direction.
SEMPER FI
Hells Dark Lord
posted July 27, 2003 05:35 PM
Ninja...if you do a serch on this board of that topic, you will find that there have been many discussions on exhausts. I sugest that you search and read....there is a lot of knowledge and expierence represented here on this board...there are guys that use there bike for a wide varity of hobbis, and an equal variety of opinions on which the best systems are....then you need to figure out what material you want it made from....then where to buy it from....lol as you can see it is a highly debateable subject.....
craigb29
posted August 06, 2003 04:24 PM
I have a Micron Full Exhaust system for sale. It includes the canister (rainbow color), and a powercommander 3. I'll let it all go for 825.00 plus shipping. The package retails for around 1,200.00 I think. Hit me on email if your interested craigb29@hotmail.com
1bad12r
posted August 06, 2003 06:05 PM
Hindle stepped system !!
768 Ryderz
JoshDunn
posted August 06, 2003 07:42 PM
Stock is the best it is so cool, Only because that is what I can afford and it helps with stealthyness(is that a word?) Seriously can you guys really feel a big power diff on the street every day with an aftermarket system? Don't get me wrong they sound so sweet and get rid of a bit more heat I'm sure. Oh well then, be easy on me.......
Yosh Tri-Oval, PCIIIUSB Tuned by Nels
k bryant
Sponsor
Yipes..................
Hells Dark Lord
posted August 07, 2003 05:42 AM
aint nothing wrong with stock JOsh.....was running with everyone here on the 1/8th mile with a completely stock 12....only the stretched bikes that were a liter or more would beat me bad...anything on a stock wheel base I was running with. But there arent a lot of big bore bikes around here, and most of them are buddies bikes, so we ride together alot, or use to anyway...they are all getting old and dont ride much anymore...
jonwright
posted August 07, 2003 06:35 AM
Josh, yes, you will notice a big difference. Personally I was rather skeptical.
Depending on what you get, if you get a full system you can loose @12-15 lbs. And the bike even rides differently! Plus the HP gain - it's a new bike.
That and -1 front sproket - hold the fook on!
I have the Muzzy full system with quiet baffle. And really, after the stock pipe blew out a bit the Muzzy wasn't that much louder than the stock pipe.
The heat comes from the cat converter right before the entrance to the pipe.
posted August 07, 2003 07:23 AM
I really like my TiForce on my 1270 bike...And my stainless muzzy on my 1347 bike!
JoshDunn
posted August 07, 2003 12:36 PM
What if you keep the stock computer, like no powercommander? What did you do jonwright? I'd like to know who has a pipe with stock programming, I really don't want to lose drivability, It runs pretty good right now, I would hate to lose that.
k bryant
Sponsor
posted August 07, 2003 01:17 PM
What I noted with the PC3r unplugged was more of the fuel curve being all over the place. We did not lose gobs of power (avg 2-4hp loss below peak). My '03 has stock engine and makes 168 hp on DJ150 with pump gas That's with Muzzy exhaust, PC3r/Muzzy Map, BMC filters. Unplugging the PC3r, it makes 167 peak, but the graph has lots of dips because of fuel delivery. But I would say the PC is mandetory on a modified engine. You simply need to be able to adjust fuel curves and ignition timing. On a stocker, not so much. But there are still benefits. I highly recommend the PC with any full exhaust change. If you buy just a bolt-on, then I'd save my money.
jonwright
posted August 07, 2003 01:21 PM
All bikes are different (even 12R's vary). I went with a full system. Mine has a big flat spot between 2.5k and 3k rpm. Twist the grip all you want and it doesn't accelerate linerally. But once it hits 3k it's back where it should be.
My Powercommander has helped that, but I'll still need a custom map to straighten it out.
I would suggest you get whatever pipe you want and try it stock. I know several guys who have done that and it's fine for them.
If you have a stumble or flat spot you wish to get rid of as well as to ensure smooth power delivery, then buy a PC - but if you do get a PC go ahead and get a custom map as well.
Some thoughts.
0.38885617256165 seconds processing time
