BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2000 ZXR12R Wont Start NEW TOPIC NEW POLL POST REPLY
dariloquis
posted February 07, 2016 04:48 PM
Hi Everyone,
Hoping some one can help.
I've had my bike for two years without a problem. A couple of months ago my battery died and I pushed the bike to start it. The bike started and I rode it for a hour or so.
The bike has been parked since. I bought a new battery and bike cranks but wont start. I try to jump it, cranks but wont start. Tested voltage 12.7, tested fuel pump, it primes for 3 seconds, when I try to start it, pump is working. I check the spark and it's good, bike still won't start.
I tried to start it with the starting fuel and bike starts and stays running but when I turn it off bike won't start again.
F1 light not flashing I don't have no codes.
Can anyone help, any ideas?
880turbo
posted February 07, 2016 05:42 PM
Did you leave it sit for 3 months with Ethanol gas in it? If so, that is probably your problem. Mike.
dariloquis
posted February 08, 2016 04:17 AM
No I always use 89 plus. I've tested everything put the bike will start only with assist Starting fuel and stay running. But once I turn it off it won't start back up. Engine spins good feel pump works Good spark. If I push it the bike starts and runs until I turn it off
posted February 08, 2016 07:22 AM
So when you say 89 plus, that's definitely ethanol free (pump is labeled as such)?
Did you do anything to preserve the fuel? Seafoam?
dariloquis
posted February 08, 2016 09:46 AM
No, you think I have bad gas? When I check spark plugs they are dry.
posted February 08, 2016 12:45 PM
Doesn't mean much fuel nowadays goes off in a month and a bit esp if there is any ethanol in it. Safe bet would be to ditch the fuel and replace it with fresh non ethanol and then you know u have eliminated that as a cause.
dariloquis
posted February 10, 2016 05:12 PM        Edited By: dariloquis on 10 Feb 2016 17:12
I put fresh gas inside. Still same problem. Fuel pump is working but looks like i'm not getting any gas inside motor.
Any other ideas.
frEEk
posted February 14, 2016 08:42 PM
"the bike will start only with assist Starting fuel and stay running" meaning if you keep pumping in "assist starting fuel"? Or once it is going, it runs fine on existing fuel in the main tank? If the former, check the fuel filter, may be clogged.
dariloquis
posted February 15, 2016 07:08 AM
Where on the bike would i fined fuel filter?
Thx
tuusinii
posted February 15, 2016 12:09 PM
Its inside tank. If you remove from the bottom the plate that is hold with bolts you'll find the fuel pump and filter assembly.
posted February 15, 2016 08:07 PM
How do you know fuel isn't getting into the engine?
dariloquis
posted February 16, 2016 04:35 AM
Because fuel injectors dont work
dariloquis
posted February 16, 2016 04:38 AM
If i spray starting fuel inside engine. Bike starts and stays running and it runs good until i turn it off. Ans wont start again without help from starting fuel
RobertMcBeth
posted February 24, 2016 04:29 PM        Edited By: RobertMcBeth on 24 Feb 2016 16:31
Check your grounds and connection at battery,
ZXLNT
posted March 06, 2016 11:14 PM
How would checking the grounds help? Its already been established above that the bike starts when you spray fuel into the throttle bodies..
Hibs
posted March 31, 2016 08:32 AM
Honestly, all this talk about ethanol is non sense. I ran my bike all year last year on E85. No issues. Let it sit for over 4 months during the winter, full tank of e85, no treatment. Charged the battery and it fired right up in seconds. Too many people spread misinformation about ethanol fuels.
0.47931289672852 seconds processing time
