BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Nutec Sp5: tune-up in a can!!!! NEW TOPIC NEW POLL POST REPLY
posted June 28, 2003 05:08 AM
I pull my bike to the track with a bashed up '94 Linc Mk8, and don't spend a dime on it that isn't absolutely required to keep it running, virtually NO routine maintenance, 130,000 mi.
Over the last 6 mo or so, it was taking progressively more starter time to fire up and I was figuring on having to get the injectors checked, etc, i.e. actually have to spend some cash on it.
BUT!!!!
A week ago I dumped several gallons of Nutec SP5 which had been diluted a bit w/pump gas (slop gas from track/street, Nutec/pump gas changeouts) into my ole hot rod Lincoln and WHOA!!!! Starts up immediately, idles smoother, runs great!!!!
I suspect that the Nutec cleaned out the injectors but who knows????
zrxdean
posted June 28, 2003 05:22 AM
I'm thinking of putting a little in my coffee...
posted June 28, 2003 06:56 AM
hmmmm......
You figure the your "injector" is clogged?????? diminished pressure???
kcadby
posted June 28, 2003 09:52 AM
It cleans the CRAP (and whatever else ) out of EVERYTHING IT TOUCHES!!!
Brock told me they're 600SS lost power after a race...they tore it down and the RINGS WERE RUSTED!?!?!?
Nuetec cleaned everything (including any oil) off of the pistons/cylinders...
NOW...they run "regular" gas through the bikes at the end of EACH DAY...NOT the end of the weekend...
ZHooligan
Post Whore Extraordinaire!
posted June 28, 2003 09:54 AM
No such thing as horsepower in a can! And when I have people tell me that I just grin and pour some more Nutec in. It is amazing fuel. Burns the shit out of your eyes and lungs in the dyno room!
future; -- Youth is forever.
Hawkman
posted July 01, 2003 09:42 AM
Where can I get some??
posted July 01, 2003 11:11 AM
Nutec
call Patty, 310 641 8015
since they are right there in LA...
worm~hole
posted July 01, 2003 12:17 PM
...sure there is..look at Muzzy's, Ti-Force, Hindle, Akro, et al
who would do us harm.”
-George Orwell
GregC
posted July 19, 2003 11:05 AM
Be careful of those kickass fuels, most will gum-up your entire fuel system within a couple of days...kcadby is correct...flush fuel system each DAY!!
RAC4IT
Bergie
posted July 19, 2003 11:09 AM
VP MR9 will make more power than Nutec and is not as corrosive, you can leave it in the bike without damaging rubber lines and o-rings.
posted July 19, 2003 12:56 PM
well, I have used nutec weekly at the track for a couple years and have called the Nutec tech on this issue. They say a couple weeks in the bike is not a problem, and I have had no problems with gumming up my system, even after leaving it in for several weeks. I do occaisonally heavily dilute the sm amount in the tank w/pump gas and run it thru the system.
I will check the pressure my fuel pump puts out, but I think the whole issue of Nutec "gumming up" a FI motor is a bit overblown. Drain daily? Not until I see some negative impact...
BTW, my motor has been apart several times for "upgrades" and each time I look for corrosion on injectors, rings, etc, and rubber going bad on fuel lines but so far I cannot detect ANY damage. I also change my oil often and have never smelled any gas in it. Go figure????
posted July 19, 2003 12:58 PM
Bergie,
have you done tests which show this? Nutec SP5 (and SP4 in olden days) adds 5-7% hp across the rpm range on my 1427.
EastBayDave
posted July 19, 2003 01:35 PM
In a pinch had to use some ERC 103 in my lawn mower. Then I got out the screwdriver & twiddled w/the mixture screw while it was running. instead of: brrrrrrrrrrrr.......it went bbbrrrrrrr.........wwaaaawweeeEEEEEE!!!
Mowed the whole lawn in a record 5 minutes; never did it so fast.
Next time I pulled & pulled, & that mower never ran again. I tink I burnt it up...tossed it....was fun mowing that time tho...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
posted July 19, 2003 03:42 PM
*laughs* Mo Power!
posted July 19, 2003 06:29 PM
I have never had a problem with Nutec, and Now I have stepped up to the Sunoco MO2X, which is great for High Compression. as soon as I have some dyno #'s I will post....
Mad Mike
posted July 19, 2003 08:08 PM
Thanks! Will be interesting to see! BTW, did you talk it over with Fish? He's an absolute wiz with PC3Rs, and would be happy to help you dial it in with that fuel.
0.25942611694336 seconds processing time
