BIKELAND > FORUMS > ZX12R ZONE.com > Thread: gasoline NEW TOPIC NEW POLL POST REPLY
aliveagain
posted June 27, 2003 11:32 AM
gasoline
Was just wondering what brand of gas(on the street)everyone uses?Iwas curious to know if there are some brands that have superior additives.I've been using Hess because it was the cheapest and yet 93 octane.
kcadby
posted June 28, 2003 09:39 AM
Nothin special here...what ever is close...
ZHooligan
Post Whore Extraordinaire!
posted June 28, 2003 09:47 AM
When I do use pump gas I use the best. 93 octane Mobil. Did I mention the fact that I own a Mobil gas station!
My advise as a guy who builds stations and has been foolish enough to keep a couple; look for for stations that is clean, has newer equipment and sells a reasonable amount of fuel. These are indicators of fresh fuel, good filters, no water or etc. in the gas.
future; -- Youth is forever.
ScaredyCat
posted June 29, 2003 06:53 AM
My bike says on the tank sticker "Use 95 or higher octane", with the threat of engine destruction if you don't.
I heard on here people are using 90 and less - although you get better power, is it worth the risk?
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
frEEK
posted June 29, 2003 06:36 PM
u mean 91 right?
EastBayDave
posted June 30, 2003 05:58 AM
Highest we can get here at "normal" brand name stations is 91; that's why I typically run (Union 76 or Chevron.) Sticker on my tank says 90 minimum.
I've run race gas a few times (ERC, Trick, etc.) but could not feel a difference...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
ZHooligan
posted June 30, 2003 07:39 AM
95 is not available as standard pump gas. Think you have misread the sticker. The risk you run is detonation and pinging. And it really isn't worth the risk. put premium in it and save the race gas for after you pump the compression up!
ZX23rr
Mahogany Bomber Pilot
posted June 30, 2003 07:46 AM
95 Octane Ron Rating equals approx 90 RON + MON/2 format. This is the standard. A rule of thumb is that if a supplier rates its fuel in RON (research octane number) subtract 5 to get a RON + MON/2. For every 2000-2500 increase in altitude, you can safely reduce the octane number by 1, if the station hasn't already. - Idaho I now offer regular gas at 85 octane, and 90 for a premium. Interior of BC at certain stations have there premium number as 91 instead of 92. Now this could be a supplier issue and 92 isn't required due to altitude.
DR JOE
posted June 30, 2003 09:00 AM
I use 87 oct pump gas and have been using it for the past 2 years with no problems. If you use race gas 100oct or higher you will lose power in a stock bike even with a pipe. I drag race mine every weekend and have run 9.22 @ 146 mph. So unless you hear it pinging stop wasting your money on high octane gas....
DR JOE
P.S. Ask Ricky Gadson what he uses???? .... He's the one who told me thats what he uses...
ZHooligan
posted June 30, 2003 09:09 AM
Running at the drag strip is one thing. Pulling a long hill on the highway in 6th gear is another. While drag racing puts stress on an engine it is not the same.
But high octane fuels of 100 plus octane serve no real purpose on non modified engines. The octane is needed for high compression to slow the burn and eliminate detonation. 91 octane on the stock compression is all you really need. Nutec is only 90 octane. But it does have some other enhancements to help it burn and make horsepower!
EastBayDave
posted June 30, 2003 05:30 PM
Perhaps I should have mentioned when I ran race gas I still had the cat, so I tried both 98 & 103 ERC unleaded race gas.
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
0.33181595802307 seconds processing time
