BIKELAND > FORUMS > ZX12R ZONE.com > Thread: i need help, please..... NEW TOPIC NEW POLL POST REPLY
Megabyte
posted June 23, 2003 06:50 PM        Edited By: Megabyte on 23 Jun 2003 19:52
I need help, please.....
After 1500 miles on my new 1361, I was stuck in traffic when my 12 started blowing black smoke and died. She refused to start, so I let her cool down. After 1/2 hour as I cranked her, she started firing sporatically, and finally fired up. I had to keep the revs up until the black smoke stopped. I put over 100 trouble free miles
on her after that, but my mileage was way down. The next morning,she repeated the same scenario when she died on the dyno, putting out 184 hp before reaching 9k rpms. Only this time, she refused to start after the cool down. Cycle barn opened her up and found the pin that holds the timing module in the cam laying in 3 pieces. That was over a month ago. Since then, the ECUs been swapped, and every other conceivable part w/o success.The engine cam timing
is nuts on, and my mechanic says the engine isn't the problem. but she insists on firing prematurely. Any ideas ? This is driving me nuts, I lay awake at night
worrying about it.
your car is slow
Fuck Nitrous...Got Boost?
posted June 23, 2003 07:25 PM
what other mods done to the bike?
Powercommander? (did you remove it and see if that cleared it up?)
Mechanical advancer?
Do not taunt happy fun ball!
jonwright
posted June 23, 2003 07:58 PM
Yeah, I used to have that problem. But I tried a little bit of numbing cream and - oh, wait. Wrong forum.
Never mind. I didn't type that.
Megabyte
posted June 23, 2003 08:03 PM
Yes, the PCiiir is disconnected, and no, it doesn't have a mechanical advancer, but I was thinking along those same lines.
Thanks,
I could use the numbing creme for my brain?
aliveagain
posted June 24, 2003 06:26 PM
is there any particulate around the timing pick up?arcing?
Megabyte
posted June 24, 2003 08:11 PM
That's a good ? to ask my mechanic.
Thanks,
flite leader
posted June 24, 2003 08:42 PM
the last time someone had a similar problem
it was the TPS(throttle position sensor)
ran sporadically
was runing ich
finally died
wasnt the ECU
was the TPS.....
good luck
bend your mind.....
or break your ass...!!
ninja12
posted June 24, 2003 08:51 PM
Check the air sensor on the left side of the motor near TPS.
Megabyte
posted June 25, 2003 06:22 AM
OK, will do.
Megabyte
posted June 25, 2003 06:23 AM
ran sporadically
was runing ich
finally died
wasnt the ECU
was the TPS.....
good luck
I've been wondering about the TPS myself. I'll pass it on.
Thanks for the help!
Megabyte
posted June 25, 2003 10:48 AM
206.6 HP w/o a map on regular gas
Mike got her fixed. Turns out the mechanic @ Cyclebarn switched two wires on the loom. She got 206.6 HP running ruff, and w/o a map. I am so happy....
thanks for all your help guys!
posted June 25, 2003 11:28 AM        Edited By: swft on 25 Jun 2003 12:29
Way cool! You might want to consider a new set of plugs. On the other hand, it just might clean up after some riding.
ZHooligan
Post Whore Extraordinaire!
posted June 25, 2003 03:51 PM
I can smell the busa(s) on the barbeque!!
I was there when they found the p[roblem and we were all smiles when we hit the starter button and she fired instantaneously. We warmed it up rolled it on the dyno and made three pulls to clkear it out. First pull 200 hp on the nose with black smoke, second pull about 1/3 as much smoke and 202 hp and the third pull a slight haze (still rich with the safe break in map Velasco puts in them) and 206.6 hp on pump gas.
Sounded great Terry, I think you will be happy once it is mapped and ready to pick-up.
future; -- Youth is forever.
Megabyte
posted June 25, 2003 08:48 PM
ZH, I am already so happy, I feel like a mountain has been lifted off my back. Many thanks for all the support you've been through this ordeal !
Megabyte
posted June 26, 2003 08:15 AM
212 hp @ 123 ft/lbs torque
Mike just finished mapping my 1361. He raised the bar a bit, 212 hp @ 123 ft/lbs torque, unfreakin believable. Sorry, but I'm still wearing a smile, and know I'm going to have a hard time not bragging about it.
posted June 26, 2003 08:24 AM
was z punching the wall with his fist cuz it wasnt the PC3?
ZHooligan
posted June 26, 2003 08:35 AM
You know whats funny Fish is even with 212 hp his clutch still works! :
0.33203315734863 seconds processing time
