BIKELAND > FORUMS > ZX12R ZONE.com > Thread: air/co2 shifter NEW TOPIC NEW POLL POST REPLY
lonniemac
posted June 11, 2003 08:16 PM
air/co2 shifter
i was wondering if any ony using these shifters are having trouble with missed shifts when attaching the cylinder to the shift rod pulling the shaft forword. the bracket to hold the cylinder is bolted to the water pump.
Cowboy
posted June 11, 2003 10:34 PM
you have to run a lot of pressure
vozizm
Got Nothing Witty To Say
posted June 12, 2003 05:05 AM
I have also heard of some guys using the NOS bottle to work air shifter...
Pros and Cons of this please?
hotrodninja
posted June 12, 2003 09:33 AM
I have that bracket, and I have to run 130 psi to be safe. It sure looks good though. If I had to do it over I think I'd mount it on the shift lever instead.
kcadby
posted June 12, 2003 10:30 AM
We have run CO2 and NO2 in John's shifter (bolted to shift-rod/water pump) for over 2-years now...NO PROBLEMS...
We run 160psi though...
vozizm
posted June 12, 2003 11:21 AM
how can i check how much psi i have ...then how can i set psi... i have a 2lb bottle!
possible pics of installation?..
kcadby
posted June 12, 2003 02:48 PM        Edited By: kcadby on 12 Jun 2003 15:48
I put a guage up by the other guages...and also have a high pressure guage at the bottle...
If you already have a pressure regulator with your air shifter kit...you can add a washer under the spring to raise the pressure...
Doug at Spencer Cycle was going to make an adjustable regulator...don't know if he did it yet???
Here are some pictures...some are of a Bbusa...the ZX12 install has the cylinder going forward to the supplied bracket that bolts to the water pump...
http://www.muzzys.com/MZAS-K12/index.html
Cowboy
posted June 12, 2003 05:02 PM
Doug does have a adjustable on the market now and it works great.
spencercyclecom
posted June 12, 2003 06:04 PM        Edited By: spencercyclecom on 12 Jun 2003 19:06
I have noticed ALOT of the bracket being made for the zx12r are flexing.....
here is our that we rleased for sale last week...NO FLEXING on this unit!!
This is the picture of our adjustable co2 regulator....the regulators are STANDARD in ALL our kits now.
cna be purchased at this link
http://prosites-spencercycle.homestead.com/Newprodrelease.html
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
0.27081608772278 seconds processing time
