BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12r ecu`s NEW TOPIC NEW POLL POST REPLY
zx12mark
posted November 13, 2014 06:58 PM        Edited By: zx12mark on 14 Nov 2014 03:00
zx12r ecu`s
Do you think a 2000 a1 ecu works correctly with a 2003 engine....
shiphteey
posted November 14, 2014 12:17 PM
No I don't.
Gemini Motorcycles
zx12mark
posted November 14, 2014 05:31 PM
And that is based on?...I`m asking because I though 03`s on down were 16 bit.
tuusinii
posted November 16, 2014 01:58 AM
It can of course be made to work but the connectors are different. As is position of the CAM sensor. So you would need to fix at least those things. Or do changes in the ECU SW. Also the map is little different but it's not good on either so thats no biggie.
tuusinii
posted November 16, 2014 02:05 AM
I think that if you would change the connector on the wiring loom (you can get those connectors online nowadays - look at the ECU hacking thread ,the ordering numbers are there) and repin the other (not sure it's neccesary but I think so) and would change the CAM pickup position to A1 specific I think it would run. Then It's just fuel mapping. BUt why would you do it? 'A2 and Bs have better mapping ability than A1. If only to get rid off 186 MPH limit I'd suggest hacking the ECU...
tuusinii
posted November 16, 2014 02:07 AM
Or if ECU hacking isin't option the Muzzy destrictor will also work - or do your own. It's really simple.
0.24686598777771 seconds processing time
