BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 48mm STACKS NEW TOPIC NEW POLL POST REPLY
FearsomeK
posted May 23, 2003 03:20 AM
48mm STACKS
Vincent has told me alot of you guys have bored your throttle bodies out to 48mm, allowing you to still use 46mm stacks.
Can anyone post a how to and mention the specific tools you used to do it.
Thanks guys.
FK
flite leader
posted May 23, 2003 08:53 PM
a first rate machine shop.......
you only get 1 shot
if it aint straight & true..... the injector throttle bdies are ruined !!!!!
probably only helps with big bore engines..... or at WOT(wide open throttle)
if you drag... if you race.... if its at bonnevile/maxton
you may actualy see/feel the difference
there again will probably not help at low to mid throttle openings
may effect idle....... just something to consider
not a criticism
otherwise a dry shot/NOS
will get you more & with less a headache
good luck
bend your mind.....
or break your ass...!!
0.44859981536865 seconds processing time
