BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Kawasaki's new Busa-killer engine.. NEW TOPIC NEW POLL POST REPLY
wannabe
posted May 13, 2003 10:22 PM
90,000 HP of penis-extending manhood!!!!
Here's the crankshaft...
Crank Housing:
Block & sleeves: (I'm can't wait for Muzzys to make a big bore kit for this bad boy.)
Zhooligan
Post Whore Extraordinaire!
posted May 13, 2003 10:28 PM
Muzzys working on a big bore kit for it. The only problem is tuning it. The Powercommander keeps taking dump when you map it.
wannabe
posted May 13, 2003 10:47 PM
The thing has a 965mm bore and a 2489 mm stroke. Can you imagine the posts?
"Can anyone tell me what the perfect gear ratio is for a 72,779,517?"
And, since this thing produces max HP at 100 rpm, maybe this post:
"Dammit! I'm getting really tired of the stumble at 2rpm."
or
"I'm getting really good fuel economy these days. Yesterday, I measured my usage at 1,660 gallons per hour."
Zhooligan
posted May 13, 2003 10:55 PM        Edited By: Zhooligan on 13 May 2003 23:57
What springs do you recomend for the clutch?
Should I drill the clutch basket or should i cough up the money for a Muzzy unit?
Can someone mail me some bear stacks to test on it?
It is obvious that the dyno you used was a "happy dyno".
My friend built the same set-up in his garage and he got 90,002 HP.
But my real question is, "is it a Falicon crank?"
By the way should I go with a dry shot or a Muzzy Wet system? How many runs should I expect from a 100 pound bottle?
wannabe
posted May 13, 2003 11:07 PM
Good ones, Z. How about:
"I think I spun a baring. Can anyone recommend any good crane operators in the Portland area?"
frEEk
posted May 14, 2003 01:05 AM
holy crap!
i assume its a ship engine? kidna surprised to see it built in korea.
zx12zx11
posted May 14, 2003 05:30 AM
Does K&N make a filter for that! Is Muzzys working on a Ti or Carbon pipe. Lets see some pounds shed off that thing.
Zhooligan
posted May 14, 2003 01:06 PM
can you imagine the starter motor and gear reduction involved!
aliveagain
posted May 14, 2003 06:16 PM
Iwant to see the torque wrench!
OZZY
need guberment cheese
posted May 14, 2003 06:35 PM
Hyundai (sp)is one of the worlds largest ship builders. They also build nearly 100% of the ship inhouse. Saw all this on one of those monster machine shows on cable.
monopod
posted May 15, 2003 07:49 PM
Do you think you can "bump start" it if the battery fails?
blubyu
posted May 17, 2003 07:58 PM
Guess which shipbuilder is larger then Hyundai!
Run whatcha brung
Tow whatcha blow
supraman95mb
posted May 17, 2003 08:57 PM
Hey Z
It revs too slow how bout we send the crank off and get it lightened!!!!
02 Stroked 12R
95 Supra Single Turbo 750+ hp
worm~hole
posted May 19, 2003 09:49 PM
..hey!...what's all that stuff in that 'big' little box on the left side of the first picture?...shoyu packets for top-ramin????...must be some sumo-sized shoyu packets if this is to scale...
who would do us harm.”
-George Orwell
frEEk
posted May 19, 2003 10:18 PM
fuck top-ramen. it's all about the kimchi baybee!!
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Kawasaki\'s new Busa-killer engine.. NEW TOPIC NEW POLL POST REPLY
0.24047803878784 seconds processing time
