BIKELAND > FORUMS > ZX12R ZONE.com > Thread: HELP! SLIpING CLUTCH IN 3RD and 4th NEW TOPIC NEW POLL POST REPLY
16-5-21
posted October 12, 2013 02:23 PM
Today while running thru the gears I noticed a slip at 10grand in 3rd. Jus a few minutes ago I tried it again now it is slipping bad in 3rd and4th when the power band kicks in. Any ideas Guys?
frEEk
posted October 12, 2013 03:50 PM
Generally means your clutch is on the way out. Never done it myself but I believe the way to diagnose is to open 'er up and measure the height of the clutch stack, see if it is within tolerance still.
Or course if you are on a hot motor with stock clutch, you may just need heavier clutch springs, or possibly a lockup clutch.
16-5-21
posted October 12, 2013 04:06 PM
I think I am just going to go ahead and order a clucth kit for it. Any recommendations?
posted October 12, 2013 04:40 PM
I just read a post in another forum where a guy had the exact same problem, his clutch slipped at 9500 rpm in 4th and 5th gears. He installed a new clutch kit and it still did it. He found out that he had put the wrong oil in it earlier. I just had a dealer change my oil last week. This might be my problem. What is the best corrrect oil to run in the 2000 zx-12. I also have get a speedo healer, I saw 208 mph today at 12,000 rpm, and I know it is off cause I have a 17 tooth front sprocket.
frEEk
posted October 12, 2013 04:44 PM
can't imagine a dealer putting car oil in, which is what would cause a clutch to slip. any bike oil (or most (all?) diesel oils) should be fine.
shiphteey
posted October 15, 2013 06:39 AM
Sounds like what mine did when the clutch was done. Oil was the normal stuff I used.
Could be oil I suppose. Try switching oil and see what happends....but its probably your clutch.
Gemini Motorcycles
posted October 18, 2013 05:48 PM
Im pretty sure it's the clutch. Any recommendations?
shiphteey
posted October 22, 2013 10:06 AM
Yes, definately stick with OEM. You will not be disappointed.
Gemini Motorcycles
0.26234006881714 seconds processing time
