BIKELAND > FORUMS > ZX12R ZONE.com > Thread: FI light comes on for 1/2 second, engine cuts out NEW TOPIC NEW POLL POST REPLY
jonwright
posted May 04, 2003 05:50 PM
Did a quick search and couldn't find anything.
Just every once in a while when riding my FI light will come on, the engine cuts out. It lasts for maybe 1/4 - 1/2 second then everything is fine again. Kinda upsetting hauling ass in a corner!
It's been very intermittent so I'm reluctant to take it to the dealer. It sounds like a short somewhere and I figure that'll be a bitch to figure out.
Anyone have similar experience, perchance?
vozizm
Got Nothing Witty To Say
posted May 05, 2003 05:54 AM
PC3...maybe?
12RPilot
posted May 05, 2003 09:21 AM
Check the codes. That always beats just blindly checking for shorts or grounds. Another thing that I heard at the track this weekend is the intermittant open due to a loose connector. I know they snap together but alot of guys put a small zip tie around each one anyway. If someone is right on your back tire, you don't need a lapse in power that you'll both regret.
jonwright
posted May 05, 2003 07:40 PM
No PC.
Thanks, pilot. I had one of those Niko plus 3's that's supposed to tweak the ignition timing and such and I figured that would be the issue. I took it off and have experienced the same thing.
Will check connections, though. Zip ties ain't a bad idea.
kcadby
posted May 06, 2003 09:46 AM
Simple to check the codes...do that...
Zaphod Breeblebox
posted May 07, 2003 08:55 AM
I've had the same thing happen to me on three separate occasions in the 3+ years I've owned the bike. ('00 model, bone stock.)
The engine will cut out briefly - 1/2 second or so - the FI light will come on for a couple of seconds, then every thing returns to normal.
The first time it happened, it actually occurred three times on a 50-mile ride. The other times it has just been a one-time occurrance.
The head mechanic at the local Kawa shop, I guy whose work I respect, claims that, in his experience, the ECUs just "glitch" occasionally. I'm not sure if I buy that. I suspect moisture in the gas.
Zaphod
Y2K ZX-12R
kcadby
posted May 07, 2003 09:35 AM
Bad gas won't make the FI lite come on though...
jonwright
posted May 07, 2003 09:54 AM
Well, it aint' right. Especially leaned over in second gear running at 8k rpm. No fun.
Zaphod Breeblebox
posted May 07, 2003 11:07 AM
Indeed. No fun at all. :o
Not sure there's a fix. Could be that the ECU is susceptible to stray RF emissions or transient undervoltage conditions...if you can't repeat it, you can't fix it.
Zaphod
Y2K ZX-12R
jonwright
posted May 08, 2003 07:27 PM
Yeah, Zaphod. I'm thinking stray tacheyon emmisons or sun spots.
I can't just repeat it. That's what really sucks. Guess I need to buy the extended warranty and figure out how to fry the ECU to get a new one.
0.83001303672791 seconds processing time
