dec11
posted August 09, 2013 03:23 AM
Oil Consumption
Is it typical for a '00 A1 to use oil? It's gone through roughly 1ltr in roughly 900miles. I do know it has that annoying leak from either the cam sensor or rocker cover. Would this cause it to lose that much? Or is it poss I have a worse prob, ie piston rings?
It's on 37K miles, runs smoothly and not smoking
Gunner
posted August 11, 2013 01:23 PM
Most probably it's leaking the oil from what you say.... FIX THE LEAK before it kills you! Sooner or later it will find a way under your times and you'll find the ground! For you sake fix any leaks it may have. I know good riders that have been taken to the pavement from a leak..
shiphteey
posted August 12, 2013 08:04 AM
times = tires.
Gemini Motorcycles
