BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx-12 gear change? NEW TOPIC NEW POLL POST REPLY
16-5-21
posted August 01, 2013 06:31 PM
zx-12 gear change?
I need to get more bottom end power to improve 1/4 mile times. What is most extreme front and rear sprocket change to accomplish this???
frEEk
posted August 01, 2013 08:52 PM
Keep in mind going down teeth in the front is hard on the chain... though if you're racing, wearing out a chain faster probably isn't a concern. I seem to recall alot of people going down 2 in the front. I'd say there's no practical real limit to how many you can go up in the rear.
That said, not sure what the best ratio for performance is. Obviously you can go too far to where your first gear is useless. May be a better question in the Dragbike Zone.
EastBayDave
posted August 04, 2013 10:25 AM
yeah hope your wheelie practice is finely honed....:lol
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
Ken 12r
posted August 04, 2013 12:29 PM
17 x 50 works good if your bike is a little longer than stock and lowered but without knowing the specification of your bike its hard to say what might be best.
www.uklandspeedracingassociation.co.uk
shiphteey
posted August 12, 2013 08:07 AM
You made no mention of your present 60 fts, 1/4 mile times, mph, wheelbase, rideheight, weight, etc.
No one can get you pointed in the right direction aside from saying at least try a 17 tooth front if you aren't able to give more info.
A.
Gemini Motorcycles
Gunner
posted August 12, 2013 03:17 PM
I always used a 17/47 combo on the 12R and liked it a lot for street use. The difference it makes is huge.. For strictly drag racing you may even think about using a 17 up front and more teeth than 47 in the rear but you will get to a point of diminished returns. You will end up making 1st gear useless and the bike hard to keep on the ground forcing you to roll out of the gas and therefore killing your et.. Gearing is a personal type thing that everyone has their preference on.. What works for me won't necessarily work for you.. Your weight factors into this a huge amount as well..
krexken
posted August 12, 2013 07:48 PM
Great post above. Don't forget that your starting line rpms are infinitely variable and your clutch can keep the rpms where you want them to be.
RAC4IT
Bergie
posted October 01, 2013 11:40 AM
If you're using the stock arm the 16/44 will will give you the maximum wheelbase and nearly identical optimal gearing, that's what I used to use back in the day.
posted October 01, 2013 04:47 PM
Siphteey. Since I'm not building a pro drag bike and tuning to pro specs, I was just looking for some friendly advise on some quick proven changes by some experienced riders in this forum. I know all about the technical side of drag racing as I have have been racing cars for the last 25 years. Since I am new to the superbike world, I thought some one could give me some experienced advise on things they have tried. But thanks for sharing your pro tips with us.
posted October 01, 2013 04:51 PM
Thanks Gunner, That's what I am going to try next. Had some new tires put on today along with brakes, a battery, and service. Have not ridden in a month and I'm bout to go nuts, but, the road is mine tmrw! Thanks Guys.
shiphteey
posted October 02, 2013 10:13 AM
"Pro Tips"?
W/out knowing what you had how was anyone really going to be able to get to where you need to be?
I mentioned 17/46 because it was cheap.
Bergie mentioned 16/44 because its the max wheelbase on a stock chain.
Gunner mentioned 17/47 cuz he wants a little more umph and 180 mph top end is still nothing to sneeze at.
Anyways good luck with your endeavors. All of these gearing setups will be getting you in the right direction. Bergie's recommendations on the stock chain setup is right for drag racing. If you're not gonna cut the chain thats the way to go. I did a 1.60 60 ft on it and I'm sure with practice 1.5s are doable when you get your clutch hand right.
A.
Gemini Motorcycles
0.21808290481567 seconds processing time
