BIKELAND > FORUMS > ZX12R ZONE.com > Thread: shiftlight NEW TOPIC NEW POLL POST REPLY
vozizm
Got Nothing Witty To Say
posted April 28, 2003 01:14 PM
shiftlight
have a Harlan shiftlight with three wires : red, black, anc green.
Red is said to be connected to a 12 volt source that turns on with the key.
Black ground.
Green is the tack input.
which is the best places for me to connect all these three wires?
wannabe
posted April 28, 2003 01:27 PM
The tach input is a light blue wire that goes into your gauge cluster. Right up there underneath your guages is probably the easiest place to splice into that wire.
The black (ground) can splice into any ground wire. I'm lazy, so I would just run it directly to the ground on the battery.
I don't know which wire it is, but I would just splice into the 12V for the parking light for the red wire.
"There are only three sports: bullfighting, motor racing, and mountaineering; the rest are just games." - Ernest Hemingway
your car is slow
Fuck Nitrous...Got Boost?
posted April 28, 2003 01:42 PM
If I recall correctly...the harlan shiftlight wont work with the signal going into the instrument cluster...I think it has to go to the #1 coil wire.
Do not taunt happy fun ball!
posted April 29, 2003 04:00 AM
Yah, unless you want to set the shift point at 46,000 rpm.
vozizm
posted April 29, 2003 04:41 AM
serious?.... YCIS....??????
damn...i thought i was gonna have a easy set up.....
now i have to locate the #1 ....help...help...help...
vozizm
posted April 29, 2003 04:42 AM
vozizm
vozizm
posted April 29, 2003 04:43 AM
underside... i glued nut to plastic {so i can remove light without nut falling or taking it back apart} and added some loctite
vozizm
posted April 29, 2003 04:44 AM
vozizm
posted April 29, 2003 04:45 AM
vozizm
posted April 29, 2003 04:55 AM
I'm no wrench!
your car is slow
posted April 29, 2003 06:17 AM
Looks good to me man.
It may work from the signal wire behind the speedo...but I dont think so :/
Just run the wire down to the first stick coil...its not THAT much further.
vozizm
posted April 29, 2003 06:37 AM
gracias !!!!
vozizm
posted April 29, 2003 07:11 AM
first as in... 1st on left if im sitting on bike?...
stick coil correct?...
looking at my manual it has 2 wires on connector one is lite colored and the other dark....
which do i tap into?....
vozizm
posted April 29, 2003 07:17 AM
#1 stick coil has a red and black...is this correct and which do i tap into?
sorry to be such a P.I.T.A.
your car is slow
posted April 29, 2003 07:27 AM
1 would be on the left yes.
Id go with red as I believe black is the ground...but I could be wrong
vozizm
.....stop doubting ...make me skkkeerreedd!!
vozizm
posted April 29, 2003 11:58 AM
you are correct YCIS....
BLACK is common on all coils and diffrent colors on the others..
#1= solid red
#2=black/green
#3=black/red
#4=black/orange
vozizm
posted April 29, 2003 12:02 PM
got this message from HARLAN...
the busa's will work on the tach lead behind the
cluster
but the 12's seem to need a connection to the coil
wires themselves. Not exactly sure why, but that has
been the easiest way to date.
you'll probably need to set it for either coil-on-plug
or 2 cylinder if you tap off one of the coil.
godd luck
vozizm
posted April 29, 2003 06:58 PM
ok...i connected green wire from light to red wire from #1 coil...hope it works...
your car is slow
posted April 29, 2003 07:46 PM
should be easy to test
vozizm
posted April 30, 2003 05:53 AM
i have no pipe on bike right now... so when i started it it was loud but i liked it!.. still no test .... as i drained the oil...
vozizm
posted May 27, 2003 05:24 AM
ok...
it did not work... i took bike out for the first time in over a month...
light wont work....
any help...
your car is slow
posted May 27, 2003 06:10 AM
In the other thread you mention you put it on the black wire on the #1 coil. Isnt that the ground?
vozizm
posted May 27, 2003 06:19 AM
correct TCIS...
but my dumb ass listened to someone who said black was the one...i first had it on red...and he told me it was wrong....
did i fuck up the light by doing this?!
0.33739805221558 seconds processing time
