BIKELAND > FORUMS > ZX12R ZONE.com > Thread: header bolt torque? NEW TOPIC NEW POLL POST REPLY
mach111
posted April 18, 2003 03:05 AM
header bolt torque?
anybody know the torque for the exhaust (8) header bolts?
i cannot seem to find them anywhere
posted April 18, 2003 08:35 AM
I use silver antiseize and use between 12 to 15 pounds. I do not trust Clickers, so I use a Beam style and rather be off 1 or 2 pounds than no having any idea!
kcadby
posted April 18, 2003 10:20 AM
I tighten them until they're "tight"
Re-check them after a couple of heat cycles
Bikelover
posted April 18, 2003 08:52 PM
If you look in the service manual for the torque for the header bolts, it just says "Stop". What does that mean?
mach111
posted April 18, 2003 09:26 PM
wonder why that manual dosnt give a torque for the header bolts?wierd..
thanks vince.
Zhooligan
Post Whore Extraordinaire!
posted April 18, 2003 09:34 PM
Well one of the reasons is it is nearly impossible to put a troque wrench on a the bolts. And certainly not all of them. And then there is the reality that you are crushing the gaskets. So the old tighten them until there tight saying is the answer. The other part of the equation is to tighten them evenly. So the exhaust gaskets will crush / compress evenly and make a good seal. And as kcadby said check them after a couple of heat cycles.
future; -- Youth is forever.
0.30504488945007 seconds processing time
