BIKELAND > FORUMS > ZX12R ZONE.com > Thread: electrical question NEW TOPIC NEW POLL POST REPLY
crashtech
posted January 08, 2013 06:09 AM
electrical question
Do any of you know if the 12R has the accessory plugs that all the other Kawis I owned have had? I want to install heated grips and dont want to go to the batt direct. I have to much shit on there as it is (12v power socket, batt tender) and HATE pulling the thing. I know the 12 has an accessory circut in the fuse box that is fused 10A. Where do you plug into it?......Thanks
tuusinii
posted January 08, 2013 11:05 AM
No, theres not those accessory plugs like in other Kawis, but You can connect Your "Abico" connector to the fusebox and ground to a good ground. But is that 10A enough for the heated grips? If You allready have a power socket couldn't You use those wires for the grips too?
frEEk
posted January 08, 2013 12:55 PM
Yeah you have to wire your own connector onto that accessory circuit on the fusebox. Mild PITA but not a big deal really.
crashtech
posted January 08, 2013 04:39 PM
RATS...I like those things, saves tons of time. Yes they are good for a 10a. I use the socket everytime I ride for a gps and dont want to overload anything since it is on a wired 15a.
Ok, I looked at the diagram in the manual. I see #6(accessory 10A) at the junction box but the lead only sticks out and ends. The other goes to a ground it appears(getting old need magnifier glass) LOL. Do I just remove the junction box from the frame and tie into it underneath? or split it and go in to the thing direct?
Thanks for the help!!!
frEEk
posted January 08, 2013 04:41 PM
Yeah just remove and attach. I don't recall for sure, but I think it just takes a standard space connector, so it is actually a pretty clean install.
tuusinii
posted January 08, 2013 10:59 PM
Yes, what freek said. Just remove the tank cover and the fuse box is there. Open it and at one end You'll find one free connector - there's all You have to do. Opening the fuse box let's You see easily what is the correct connector. Anyhoy I think there is only one free anyhow but just to be safe.
Toni
crashtech
posted January 09, 2013 05:39 AM
Cool, Thanks fellas. I will get them on the next couple days
crashtech
posted January 09, 2013 04:08 PM
LOL...its got 2, one open on each end of the plug..
0.33666396141052 seconds processing time
