BIKELAND > FORUMS > ZX12R ZONE.com > Thread: HELP!!!! What happened? Bike will not start NEW TOPIC NEW POLL POST REPLY
kawdawg
posted April 09, 2003 03:58 PM
I had to change my subframe on my 2002 12. The bike ran before I took off the subframe. I take off subframe with no problem. Only a couple of electrical conections to disconnect. I put on new subframe and now the damn thing will not start. It turns over normally and fuel pump kicks on. My light on my power commander will not come on either. I unhook the Power Commander and hook it back up like stock thinking something might have happened to the PC3. Still I get nothing. I do diagnostic.I ground the conector out and the FI lights comes on but does not blink a code. The light stays on steady. Checked the connection numerous times. I also checked all the fuses and all were good. Is there a fuse or something somewhere else? What did I do? Any Ideas?
Zhooligan
Post Whore Extraordinaire!
posted April 09, 2003 04:40 PM
Is everything grounded corectly? Quite a bit of the stuff in the tail is grounded to the subframe as aI recall.
future; -- Youth is forever.
Wildman
I only look confused
posted April 09, 2003 08:11 PM
Did you change out any electrical parts?
I seem to recall someone saying something about a connector back there that was possible to put in the wrong place and burn up stuff. I think it was just on the 2000's, you didn't put a 2000 subframe on did you?
and of course check grounds, make sure it's grounded to the main frame. I dunno if there is a grounding strap or it just goes through the mechanical connection, look for corrosion at all ground points.
If you build something Idiot Proof, The world will build a better Idiot.
0.24282693862915 seconds processing time
